Old Jan 23, 2013, 06:30 PM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
I need to tag this one.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Jan 24, 2013, 06:03 AM
LuftM40 is offline
Find More Posts by LuftM40
LuftM40's Avatar
Joined May 2011
Great model...love the lines of the Spitfire. On the painting; yes, light colors should be applied first, then darker ones. If you are masking w/ something other than professional products (like plain masking tape), use a straight edge and an exacto to recut the edges. Tape right off of the roll actually has jagged edges that can cause an irregular line and bleed under. A trick I use for camo schemes and other curved lines is to cut a very thin strip of masking tape...thin enough to bend and curve. This forms the paint line, then I fill in behind it w/ larger pieces of tape.The clear coat trick works, but you can also lightly burnish the tape edges down w/ a toothpick. Also, don't be afraid to use multiple light coats that dry quickly, and avoid spraying paint directly at the tape edge. This avoids the paint build up, which causes ridges and bleeding...
LuftM40 is offline Find More Posts by LuftM40
Old Jan 26, 2013, 01:21 PM
dweeb7944 is offline
Find More Posts by dweeb7944
Dweebster
dweeb7944's Avatar
United States, MA, Charlton
Joined Sep 2008
perfectplanes, I used a CB Associates spinner, which I believe is the P-40 one. It's shape is different than the P-51 version they have.
Thanks for the tips, LuftM40. I'm always looking for ways to improve.
Still waiting for spring.
dweeb7944 is offline Find More Posts by dweeb7944
Wanted Dynaflite Spitfire plans or kit fomocokid Aircraft - Fuel - Airplanes (FS/W) 10 May 15, 2012 05:51 PM
Sold Dynaflite Fun scale Spitfire ORANATOR Aircraft - Fuel - Airplanes (FS/W) 4 Mar 28, 2012 10:33 PM
Discussion Dynaflite Butterfly questions/build log. ejam Beginner Training Area (Fuel) 26 Oct 08, 2009 12:16 AM
Build Log Dynaflite daydream question! Now Build Log! F3aFlyer Electric Sailplanes 13 May 07, 2009 06:14 PM
Wanted Wanted: 80" Dynaflite Spitfire kit kenair Aircraft - Fuel - Airplanes (FS/W) 2 Oct 20, 2007 01:09 AM
