Old Oct 13, 2009, 11:00 PM
AllanK1 is offline
Find More Posts by AllanK1
Blenheim, NZ
Joined Dec 2007
1/2A Tex vintage Chilton build.
Hi, I thought some of you 1/2A guys might be interested in my little Chilton DW1 build log.
http://www.rcgroups.com/forums/showthread.php?t=1079805 this link will take you to my vintage build log.
This is for 1/2A texaco vintage here in New Zealand.
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Oct 14, 2009, 08:28 AM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
That looks nice! Is that "rag" wrapped around the ports used as a muffler? Or is it just to keep stuff out while not being run?
James
Deuce is offline Find More Posts by Deuce
Old Oct 14, 2009, 01:38 PM
Tee Bee is offline
Find More Posts by Tee Bee
Nice looking project!
Tee Bee is offline Find More Posts by Tee Bee
Old Oct 14, 2009, 02:55 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
James
I'm sure you know the answer to that! This little BabeBee is amazing. Most of us struggle just to get reliable runs form these little beasts and I know I have struggled with them off and on for 45 years! This one is a real beaut though. It regularly runs 5 minutes 30 secs plus on that smaller standard Cox tank. That may sound a lot but it is done for competition by running a large electric slow fly prop 9 x 4.25 cut down to 8.5 and the fuel has more energy by reducing the oil to 7% and the nitro to 5 % with the rest being methanol. I have fiddled with the head shims too but currently she is unshimmed.
I can't beleive how lucky I have been with this one.
Yes, I definately don't want dirt in it!
Allan
Old Oct 14, 2009, 07:02 PM
Deuce is offline
Deuce's Avatar
Joined Jul 2006
Impressive! I admit I have yet to ever time the run of one of my Cox's! Haven't done any competition flying, so that's most of it!
Indeed, keep that one pristine!
James
Old Oct 14, 2009, 09:59 PM
ZEROSKIN76 is offline
Find More Posts by ZEROSKIN76
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
3minutes 34 second average
my babe bees with dual slit newer cyl and no shims will last 3 minutes and 34 seconds on 15 percent or 2 min 15 seconds on 24 percent both are 17 percent all castor lubed i get much less run time out of my old bees with large single slit bee cylinders and have one that will kill that 4cc tank in matter of 45 seconds it is a rc sleeve milled cylinder very large openings = more wasted gas but amazing proformance
ZEROSKIN76 is offline Find More Posts by ZEROSKIN76
Old Oct 15, 2009, 06:51 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
Yes all these little engines seem to run (or not) differently. I think if had to rely on Cox engines as a kid i would have given up. Fortunately we had good supplies of English diesels and then Japanese glow motors for the bigger stuff.
The real trick to get long efficient run is the big broad electric prop which turns at very low speed. The prop is thin and very efficient and the lower rpm seems to drop the fule consumtion rate considerably.
I have run lots of tanks through at 5% oil with no sign of wear at these low speeds. I use cool power 50 / 50 caster synthetic. Burns really clean as you would expect and the motor never gums up.
Allan
Old Oct 16, 2009, 03:41 AM
salat is offline
Find More Posts by salat
Trying To Takeoff
salat's Avatar
Novosibirsk, Siberia
Joined Dec 2006
what brand of electric prop was used?
salat is offline Find More Posts by salat
Old Oct 20, 2009, 05:33 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
ASP? APS? slow fly 9 by 4.3 cut down to 8.5 from memory.
Clearly you need to be carefull using an electric prop on IC as they are much lighter in the hub and blade generally. These big ones turn slow though like their electric application and have been fine on my motor.
Allan
Old Nov 10, 2009, 03:41 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
Chilton finished
Some pictures of the finshed DW1 for you all. Now the Babbee is running properly she is flying great but pretty lively around all axiis. 6 minute engine runs.
320 sq ins, 46.75 inch span, just 19.5 ozs ready to fly.
Covered in Solite with hand cut decals in the same film.
Looks very cool in the air.
Allan
Old Nov 10, 2009, 06:44 PM
Tee Bee is offline
Congratulations! That's a beautiful model airplane.
Old Nov 15, 2009, 03:35 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
There are some flying shots over on the build log if anyone is interested.
Allan
Old Nov 17, 2009, 03:35 PM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
by far the nicest airplane ive seen flying on a babe bee
wow this was an amazing build i wish i had your talent
i love those old nostalgic planes
but you really outdid most Ive seen
Old Nov 18, 2009, 08:14 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
Cheers Zeroskin, I'm sure you sell yourself short. It is a fairly straight fwd model.
Allan
Build Log Herr 1/2A P 51 build/ conversion (maiden complete) (back to glow) commrad Glow to Electric Conversions 71 Jun 06, 2009 04:19 PM
Elexico (1/2A Texico) plans/kits rht0930 Electric Plane Talk 3 Apr 07, 2009 06:07 PM
Discussion Vintage 1/2A LannyG 1/2A Planes 12 Dec 20, 2006 01:42 PM
want to build a 1/2a plane,.. which one anthony_marquart 1/2A Planes 5 Dec 24, 2004 12:49 PM
Converting a Sureflite 1/2a Cub to electric ARCHER7153 Foamies (Kits) 2 May 21, 2001 12:05 AM
