Old Nov 13, 2008, 10:45 PM
El Dorado Hills, California
Joined Nov 2005
motor brake on esc - why is it needed?
Why would I want the motor brake on vs. off on my brushless ESC?
alpinex is offline Find More Posts by alpinex
Old Nov 13, 2008, 10:56 PM
charge em up!
Zamfir's Avatar
Colorado
Joined Jul 2007
motor brake forces the prop to stop spinning and allows it to fold for gliders. It can also be used to slow the speed of the plane when going straight down when doing pattern type flying to keep the speed the same as the rest of the routine.
Zamfir is offline Find More Posts by Zamfir
Old Nov 13, 2008, 11:09 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Also is used for AV/AP where vibration will reduce the quality of the picture.
1320fastback is online now Find More Posts by 1320fastback
Old Nov 13, 2008, 11:11 PM
Joined Nov 2005
So, is it better to have the brake on to reduce vibe and drag?
Old Nov 13, 2008, 11:18 PM
John,not Zerts.JOHN, NOT Zerts
USA, AZ, Chandler
Joined Nov 2007
Brake on is also good for beginners when you get those frequent prop to ground collisions. Also good for safety reasons in general but not good for 3D flying.
Zerts is offline Find More Posts by Zerts
Old Nov 14, 2008, 10:35 AM
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
^Well, I use brake on and brake off for different 3D planes.
Xpress.. is online now Find More Posts by Xpress..
Old Nov 14, 2008, 10:42 AM
USA, AZ, Chandler
Joined Nov 2007
I admit- I am a 3D noob, what is the criteria for brake on/off with 3D?
Old Nov 14, 2008, 10:53 AM
Beware Of The Shills !!!
Chichester Sussex
Joined Aug 2007
When the brakes off the propeller windmills which helps to slow the plane down, in 3D you want to be able to fly the plane generally slower and smoother so it's better to have it off - - so to speak .
The other place you'll notice a big difference is landing, one of my planes I fly in longish grass and belly land so have a soft brake to avoid breaking props. It takes a much greater distance to glide it in and comes in faster whereas the planes I don't switch the brake on you can fly them in to land a lot slower and more accurately.
Witterings is online now Find More Posts by Witterings
Old Nov 14, 2008, 02:33 PM
Hitec RCD CSR
Xpress..'s Avatar
Joined Oct 2007
I'll turn the brake on if I'm using a rubber band prop saver, but if I use a solid prop adapter, then I turn the brake off, to keep the prop from stopping in a vertical position, and breaking on contact with the ground.
Old Nov 14, 2008, 03:49 PM
USA, AZ, Chandler
Joined Nov 2007
OK, the motors I use have such strong magnets they self-brake if the ESC brake is set to off. Just takes longer for the prop to stop spinning.
Old Nov 14, 2008, 04:02 PM
I havent decided yet
Indiana
Joined Jun 2006
even with the strong magnets you will see that the prop will keep spinning on a down line with the brake off. that helps keep the speed down. once the prop stops spinning the plane will go faster. I dont use the brake on any of my planes. you really want no brake if your plane has a habit of gliding too far on landing. the windmilling prop will slow it down.
dmiller746 is offline Find More Posts by dmiller746
Old Nov 14, 2008, 05:14 PM
Joined Nov 2005
OK, so have to land in a small area (dead end road), so having the prop help slow down the plane would be a good thing for me. I'm not too worried about breaking props, they're cheap compared to the price if I overshoot my landing area while traveling too fast.
Thanks for the info.
Question ESC.. Brake vs No Brake on brushed motor? bartricky Beginner Training Area (Aircraft-Electric) 3 Mar 16, 2008 09:22 PM
Discussion Hard or soft brake on esc G-unit Electric Sailplanes 10 Jan 15, 2008 05:51 PM
Discussion brake on esc haggerty Power Systems 1 Oct 07, 2007 07:43 PM
Discussion F5D brake or no brake on esc jaywatay High Performance 5 Dec 12, 2006 01:04 PM
Motor brake on or off for non folding prop? Herky-Bird Sport Planes 5 Sep 09, 2001 06:31 AM
