Old Nov 17, 2014, 01:35 AM
United States, TX, Lipan
Joined Jul 2013
Go Kart Chain PSRU
I'm seriously considering using #35 chain and sprockets to reduce prop speed and gain efficiency of a larger prop while reducing prop noise. Seeing several engines so equipped it doesn't appear to be a major task. Since chain is a no-slippage drive the thought of adding a starter/generator also seem possible. Has anyone had similar ideas or have completed making a chain Propeller Speed Reduction Unit? Ed
Geek1945 is offline Find More Posts by Geek1945
Old Nov 17, 2014, 05:29 AM
Works fine
Gary Cee's Avatar
United States, MI, Marysville
Joined Apr 2010
What size engine and prop ? For many smaller applications #25 may be a better bet . The chain either way is pretty heavy , as are the sprockets , unless you use nylon sprockets . Nylon is a lot quieter as well . You should also fit a chain retention "guard" of some kind to contain the chain should it happen to dismount .
Toothed belt drives are probably a better solution . Perhaps a bit less efficient from a power standpoint but lighter and quieter than the roller chain . Again nylon sprockets win at the scales .
Gary Cee is offline Find More Posts by Gary Cee
Old Nov 17, 2014, 09:41 AM
vic welland's Avatar
Valdese NC
Joined May 2004
This has been done successfully in the past.
http://www.bing.com/images/search?q=...electedIndex=1
vic welland is offline Find More Posts by vic welland
Old Nov 17, 2014, 09:52 AM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well the Wright Brothers used a chain drive to power the dual props on their Wright Flyer. I remember seeing a few engines with reduction drives using chains and sprockets before too. So it is possible, Usually most everyone opts for a toothed belt drive or gears though. There were some planetary gear drive units made in the past too.
earlwb is online now Find More Posts by earlwb
Latest blog entry: My new Gaui X5 Rc Helicopter
Old Nov 17, 2014, 02:34 PM
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
tony clark and another european manufacturer also do belt reduction drives. ultralights and PPGs also use reduction drives and it's either belts or enclosed gears, never seen chains used. belts are going to be quieter, lighter, last longer and are just more suitable at these speeds. mcmaster-carr is your friend...
ZAGNUT is online now Find More Posts by ZAGNUT
Old Nov 17, 2014, 03:49 PM
You could look up some of the chain suppliers to see what the maximum recommended running speed would be.
I'd agree that a timing belt would probably be a better alternative.
706jim is offline Find More Posts by 706jim
Old Nov 17, 2014, 07:39 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
A while back I saw some old common combustion engines that were used in large RC helicopters at the time. I am talking something with a ten foot rotor span or more. There was a two cylinder setup and a three cylinder setup. They all used a chain to connect the engines together to keep them in sync.
So it isn't really a bad idea to use a drive chain as a gear reducer for driving larger propellers. Now it may not be the best way to do it though. But it would work.
For belts, sprockets, chains, pulleys, gears et cetera, I suggest perusing Stock Drive Products out.
http://www.sdp-si.com/
You can easily spend days going through their catalog perusing things and coming up with ideas for all the neat stuff they have. They have pretty much everything one could want too.
Old Nov 18, 2014, 12:17 AM
Reginald's Avatar
Belgium
Joined Aug 2004
some examples of chain or belt driven engines, last two pics are the smallest model chain I know off by Kyosho and a mere 3mm wide ( note that sprocket was home made for my Blériot wingwarping system ) large chain driven engine is obviously missing a spring tensionner ! The Kyosho chains are used on the gokart.
pm : noticed there are quite a few Kyosho chains on ebay and some include sprockets, never knew that
Reginald is online now Find More Posts by Reginald
Old Nov 18, 2014, 08:15 AM
United States, FL, Citrus Springs
Joined Aug 2008
Are we talking about just chain, or PSRU units in general? What size engine/prop?
Byron used to use a of of PSRU's in his bigger stuff, even gear drives? If looking smaller, wasn't too long ago there were a lot of belt reductions used with electric installs.
ahicks is offline Find More Posts by ahicks
Old Nov 26, 2014, 12:55 AM
Joined Jul 2013
After researching chain drives and viewing several in action on 30cc and bigger engines commonly used for large scale RC, it appears to be a viable option for PSRU's. Roller chains appear to be the most commonly used type drives on motorcycles which are easily purchased and replaced. Most belt OEM's advise against using tooth belts preferring multi-vee for PRSU's due to torsional stress. Like belts some basic guidelines are; keep shaft centers < 80 pitches, running speed <3000 ft/min slower is better, drive sprocket should be >17 teeth, chain tension should be some what loose i.e. like chainsaw or use a spring tensioned idler or nylon rider once set with a new chain DO NOT READJUST. Normally a roller chain is considered worn out when stretched 1.5% allowing additional stretch will also damage sprockets which should be avoided. Obviously the sprockets will need replacement, this time can maximized by timely maintenance and measuring wear. All motorcycled dealers and websites have custom chain lubricates which greatly reduce sling off since most riders like to show-off their bikes without chain lube splattered on rim and fender. Considering most roller chains meeting RC needs are #25 & #35 (1/4 & 3/8) pitch are normally sold in 10' lengths for <$20 there should be no reason to except excessive wear. It's is advisable to purchase extra master links when ordering chain. Like belts, chain quality is usually price related with premium chains costing more. Motorcyclist seem to favor o-ring chains made by Tsubaki but, that is just my observation. Since weight is always a concern aluminum driven sprockets are preferred, in the event you have to purchase a steel one consider making lightening holes to reduce weight. Likely your drive sprocket will be hardened steel, it is advisable to avoid single digit ratios i.e. 2:1 3:1 and so on to cancel engine harmonics while still increasing propeller efficiency. It is advisable to use smaller diameter shafts since they also help reduce harmonic vibrations along with lower prop speed. Depending on your airplane's design and engine performance curves most props work best in 1800-2300 rpm range, again this is based on general aviation airplanes with 5-6' props. As you already know even light planes are noisy so don't expect a stealth model either but, lower frequencies are considered better.
See this link for how to measure wear: http://www.chainweargauge.com/roller...hain-wear.html
Old Nov 26, 2014, 05:09 AM
Works fine
Gary Cee's Avatar
Joined Apr 2010
Goooood luck ..............
Old Nov 26, 2014, 06:32 AM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
One thought it that with motorcycles, they gear down the engine using a transmission. The final drive sprocket is thus turning low RPMs compared to the engine. Maybe 1,000 RPMs tops. That has me wondering what the maximum speed is for a chain drive. If the engine is turning say 12,000 RPMs and the sprocket and chain is running at that speed, will that be a problem? Even with a large gas engine turning 6,000 RPMs is still a huge speed for the chain and sprocket. Now I know the overhead cam engines use a chain drive, but the load stresses are different than being driven for power off the crankshaft. So it had me wondering what speeds the chain and sprockets can handle.
Old Nov 26, 2014, 06:50 AM
Works fine
Gary Cee's Avatar
Joined Apr 2010
The speed ratings are specified in manufacturer's data . Most motorcycles also employ torsional dampers to minimize shock loads . Chain slack tends to magnify the problem .
We are somewhat at a disadvantage here since the OP has provided little information regarding engine type and size , prop specs etc . The chain maintenance tutorial is a given , Not sure what it has to do with the question at hand . Most of the #25 roller chain is plain bearing , unsealed if I recall correctly . Unlike belt drives , plain chain usually requires regular lubrication . Noise is cumulative so chain will add noise and absent isolation will also tend to transmit noise .
I know there have been quite a few successful toothed belt drives for model aircraft . Multi vee or poly grip belts generally require a measure of radial loading to provide adequate grip . Our engines are designed primarily to absorb end thrust loads , less so radial loading . Chain drives will increase the radial loading to some extent , I suspect a multi vee drive could generate an even higher load .
Often there is need for a spring loaded idler to keep the belt adequately tensioned and take up belt stretch .
Old Nov 26, 2014, 07:26 AM
Joined Aug 2008
To the point I just don't see it being practical in the rpm ranges we would be talking. Even if were were talking about a multiple stage reduction, the initial stage is going to be turning a lot faster than anything I've seen turning - except for maybe the cam drive chain on some bikes. Of note there is that they're using some pretty good size sprockets (much bigger than 17t). If this is a can it be done project, I'd say it is. If it's a can it be done practically exercise, I'd have to change my vote....
"Chain drives will increase the radial loading to some extent."
Old Nov 26, 2014, 07:27 AM
Goodnight Irene
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Having raced go-carts, I would shy away from chain for RC applications. #35 is not and I assume #25 chain are not true roller chain as in there is no roller on the link. I found wear to be excessive. But in a racing application it was part of the game. I would go the belt direction if at all possible. It will be a much smoother drive and should last much longer with fewer issues.
Ken
kenh3497 is offline Find More Posts by kenh3497
Off Site Turnigy Go Kart. bigmagoo Cars - Cars and Parts (FS/W) 8 Jan 07, 2014 11:10 AM
Sold $100.00 shipped must go! KT8 BRUSHLESS Go Kart RTR reptileman Cars - Cars and Parts (FS/W) 1 Nov 08, 2013 09:47 PM
For Sale Brushless go kart reptileman Cars - Trucks and Parts (FS/W) 0 Oct 27, 2013 08:42 AM
Yippee! RC Karts : Who's going to Battlefield RC in Georgia for TERC kart races? CeriJonston Large Scale Cars 141 Feb 09, 2013 01:10 PM
Discussion Nitro Racing Kart, Live Axle, Chain Drive, Disc Brakes, Recoil Start CONDOR2 Nitro and Glow Power Cars 1 May 19, 2011 08:52 PM
