Old Oct 03, 2012, 09:38 PM
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
LED Driver?
Hi Guys,
I want to use some 1 watt LEDs for nav lights. The LEDs run on 3.0 - 3.2V and a constant 300 to 350 mah to make the last longer. Do I need a driver for these LEDs or can I simply use a resistor to drop the voltage? I'm slightly "electronically challenged" so any info would be greatly appreciated!
Thanks!
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Oct 04, 2012, 09:11 AM
Ohio
Joined Nov 2003
A resistor is ok if running off one lithium cell, but if running on 12V, a buck convertor is
in order. National semi, LTC, Maxim, others have them. Switching step down regulator.
jglenn is offline Find More Posts by jglenn
Discussion Flexible little LED Driver for 1W LEDs KTMRacr Night Flying 2 Aug 12, 2012 10:45 PM
Discussion LED Driver discovery for 1-W LEDs barb wire Night Flying 0 Sep 14, 2010 05:18 PM
Discussion 34063 switcher as high-power LED driver flieslikeabeagle DIY Electronics 12 May 04, 2009 12:27 AM
Help! PWM & LED driver rocky79 DIY Electronics 23 Sep 05, 2007 05:07 PM
Mini-HowTo Constant Current LED Driver for 2s li-po and above z-matrix DIY Electronics 2 Nov 06, 2006 01:16 PM
