Closed Thread
Old Jul 03, 2011, 05:36 PM
Noob
Joined Apr 2011
Cell fluxuation...
Hiya,
I have a Flightmax (from HK) 1000mah 3s lipo pack that I've had no issues with for about 20 or so cycles.
Recently, I happened to be watching the individual cell voltages while balance charging the pack. Something odd was happening...
One of the cells was intermittently showing 1V. While that cell dropped to 1V, the second cell showed 7+V, basically as though it was reporting the voltage of 2 cells. It would do this for about 2-5 seconds, then return to "normal" with all 3 cells showing voltages in the correct range.
Is this just an anomaly with the reporting of cell voltage or should I stop using the pack and dispose of it?
Thanks!
Update:
So, it looks like I've found the issue, but it leads to another question. One of the wires from the balance lead has disconnected from the battery, which would explain the intermittent issue. Can I solder it back on or is it dangerous?
Update 2: Found some other threads on soldering the leads back in place. Should be no problem. I'm closing the thread, since the issue is solved.
May all of your take-offs and landings be equal!
Oakstone is offline Find More Posts by Oakstone
Closed Thread
For Sale Brand New Traxxas Power Cell 7 Cell (8.4V) 3000mAh Nimh battery and Charger zsultan Cars - Cars and Parts (FS/W) 1 Mar 19, 2015 11:48 PM
For Sale Brand New Traxxas Power Cell 7 Cell (8.4V) 3000mAh Nimh battery and Charger zsultan Cars - Trucks and Parts (FS/W) 0 Jun 26, 2011 01:29 AM
Sold Traxxas Power Cell 7 Cell (8.4V) 3000mAh Nimh battery and Charger. zsultan Cars - Cars and Parts (FS/W) 1 Jun 25, 2011 08:53 PM
Sold Traxxas Power Cell 7 Cell (8.4V) 3000mAh Nimh with traxxas connector and charger. zsultan Cars - Trucks and Parts (FS/W) 0 Jun 24, 2011 11:45 PM
RPM fluxuation in P10 governor mode TimGoldstein Castle Creations 10 Jun 14, 2004 01:52 AM
