Old Sep 14, 2010, 11:51 PM
maddmann is offline
Find More Posts by maddmann
maddmann's Avatar
USA, OH, Newport
Joined May 2005
Can it be 2.4- Futaba FG radio with AM module
I've got a Futaba FG series radio that has an AM module. The module is FP-TF-AM which is slightly bigger than the modules used on the newer radios. Has anyone converted one of these to 2.4ghz and if so ho was it done? This one is 6 ch and has dual rates and servo reversing. It would be nice to use it on small electrics and such. If anyone has info. on converting this to 2.4 I would appreciate it.I can solder and modify circuits, I just need the info.
maddmann is offline Find More Posts by maddmann
Old Sep 15, 2010, 12:02 AM
bnrusso is offline
Find More Posts by bnrusso
early retired & loving it
USA, AZ, Kingman
Joined Aug 2005
Heres some info:
http://www.rcgroups.com/forums/showthread.php?t=977807
I think you should be able to do any of the DIY hacks as your radio, even though it was AM, should put out PPM to drive any 2.4G module.
look up DIY threads about ASSAN/ FR-sky/ fly-dream, corona or ...?
bnrusso is offline Find More Posts by bnrusso
Old Sep 15, 2010, 04:31 AM
Harri Pihl is online now
Find More Posts by Harri Pihl
Suomi, Lšnsi-Suomi, Uurainen
Joined Jan 2004
Should be possible; the FG series (Gold box) radios could use AM or FM modules and the PPM signal can be taken out from the module pins (internal or external module).
However, the older FGs had the servo center point at about 1,3 ms instead current standard 1,5 ms so this should be adjusted as well. There are couple potentiometers inside in the circuit board for this and with osciloscope this is doable.
Harri Pihl is online now Find More Posts by Harri Pihl
Old Oct 07, 2012, 09:55 AM
RWalker is offline
Find More Posts by RWalker
United States, CA, Lancaster
Joined Nov 2011
I'm just joining this thread to study changing an AM FG series. The one I have has a sticker that says 1.5 ms on the bottom rt corner of the case. So it should be good to go.
RWalker is offline Find More Posts by RWalker
Old Oct 07, 2012, 01:28 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The old Futaba had a center pulse of 1.34ms instead of the more used1.5ms, it would have been a problem with the older servos which had a square output(but you could adjust the pot in most with a small screwdriver for neutral). With modern servos with a spline output its only a matter of moving a few notches to get the arm positioned when the stick is centered. The older AM serie were using "G" type servos connectors instead of the "J".
coriolan is offline Find More Posts by coriolan
Old Oct 07, 2012, 02:24 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Here's a nice hack model that should work for you, and you don't even have to order from China
http://www.alofthobbies.com/frsky-v8ht-diy-module.html
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Oct 08, 2012, 01:28 AM
RWalker is offline
Joined Nov 2011
Okay, let's talk finding those wires on the AM FGs. I plan to solder onto the trainer socket. There are four wires, red, black, brown and yellow that go to the board. I figure the red and black are positive and negative, it's a question of the yellow or brown being signal. Also, there is conventional wisdom that AM type FGs can't be upgraded. Perhaps the hack you linked too makes this possible?
UPDATE: I have found the brown wire connected to the trainer socket to be the PPM signal wire. Got my FrSky DIY module installed and running!
Old Oct 10, 2012, 03:11 AM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
We have had customers convert radios much older then the Futaba FG series, like 20+ years older. So the FG should not be much of an issue. Most all old radios that are 8 channels or less should have a PPM signal floating around you can pick up.
I usually look at the trainer port, and trace the PPM back from there.
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Latest blog entry: FrSky @ Toledo 2015!!!!
Old Oct 10, 2012, 09:54 AM
pilotpete2's Avatar
Joined Jun 2004
RWalker,
Here's a thread for hacking a Spek DM8 module contains pinouts for the Futaba round DIN trainer port, you just have to scroll down a ways.
Should be easy to install the FrSky internally, picking up the PPM from the trainer port.
http://www.rcgroups.com/forums/showthread.php?t=1556607
Pete
Old Oct 10, 2012, 08:49 PM
RyanNX211 is offline
Find More Posts by RyanNX211
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
Why turn a Futaba into a Spektrum?
RyanNX211 is offline Find More Posts by RyanNX211
Old Oct 10, 2012, 09:58 PM
RWalker is offline
Joined Nov 2011
So, if I read the pin right, I want to tap into the ground, ppm out and battery?
Old Oct 10, 2012, 10:02 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
In this thread,because the Futaba is an old AM radio.
In the linked thread, possibly to be able to fly all the cool BNF stuff?
pmackenzie is offline Find More Posts by pmackenzie
Old Oct 11, 2012, 05:37 AM
RyanNX211's Avatar
Joined Dec 2007
I thought that might be so.
Even some people I know who have abandoned Spektrum still keep a transmitter on hand to fly the small models they build using the little bricks from the HH toys.
Sold Futaba Attack-4 75 MHz AM Surface Use 4 Channel Radio Charlottedarter Boats (FS/W) 4 Sep 06, 2010 01:53 PM
For Sale Futaba Conquest AM Radio 4 chan nib Kilowatts Aircraft - General - Radio Equipment (FS/W) 0 Sep 05, 2010 03:25 PM
Discussion Futaba 6EX 2.4 GHz with subtrims ..can it be done ?? ? khaled_abobakr Radios 8 Oct 17, 2009 02:08 AM
For Sale am futaba oldies FG RADIO WITH RECEIVER Rhondas Aircraft - General - Radio Equipment (FS/W) 1 Jun 09, 2009 03:45 AM
WTB Futaba FG RF Module 54 or 56 AM old_dude Aircraft - Electric - Airplanes (FS/W) 0 Feb 01, 2002 06:54 PM
