Old May 22, 2015, 12:57 PM
Mad_Mike is offline
Find More Posts by Mad_Mike
Be safe son - Fly low and slow
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
Question
First water plane
Hi guys:
I'm half way through the "Post pics of your float planes" thread and I'm keen to get a project underway.
- I want to build from scratch.
- I would like a boat type plane.
- I want it to be simple to build.
- I'm thinking 24" - 30" wingspan 3/800 battery and suitable motor.
- 4 channel
It needs to be "Disposable" because I'll be making all the usual mistakes(whatever they are)
I'm just looking for some rough guidance and Do's/Don'ts on the airframe.
Any help appreciated!
Mad_Mike is offline Find More Posts by Mad_Mike
Old May 23, 2015, 07:11 PM
scott swanson is online now
Find More Posts by scott swanson
Letís eschew obfuscation.
scott swanson's Avatar
United States, SC, Walhalla
Joined Apr 2009
Mad_Mike,
Your "disposable" criteria suggests to me a foamie. You might want to check out the scratchbuilt foamies forum.
The answer to a question similar to yours is at http://www.rcgroups.com/forums/showthread.php?t=1915065. See if any of these meet your needs. I would also add to this list my own SlowBoat at http://www.rcgroups.com/forums/showthread.php?t=1864719, but you may need to add a bit of nose weight to get it to ballance with an 800mA battery (it's designed for 1350mA).
Scott
scott swanson is online now Find More Posts by scott swanson
Old May 23, 2015, 08:43 PM
Wormboy is online now
Find More Posts by Wormboy
Wormboy's Avatar
Australia, WA, Madeley
Joined Jul 2011
Im assuming you have some flight experience and are just migrating to the water?
My advice would be a Polaris as it satisfies almost all of your criteria. Its just a little bigger than specified.
Its a flying boat rather than a float plane
4 channel
Super stable and easy to fly providing you have a few hours under your belt
Scratchbuilt foamy with the build taking between 12 &18 hrs.
Free plans
What's not to love!?
There is an extensive build thread on the polaris. With all of the do's, dont's and tips you could ever want.
You could always build a 75% as many folks have done but the smaller it is the faster and less forgiving it becomes.
Wormboy is online now Find More Posts by Wormboy
Old May 24, 2015, 07:47 AM
Mad_Mike is offline
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
Thanks guys.
That gives me lots to look at.
I've looked at the videos of your Slowboat Scott and like it a lot.
It's got a lot of parts though and I don't want to spend too much time on a disposable airplane.
I can fly fairly well but I still have the odd disaster.
The Slowboat might be my second waterplane, and I'll build it with the power system you specified.
Old May 24, 2015, 05:17 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
Originally Posted by Mad_Mike View Post
Thanks guys.
If I was going to build a flying boat - I would make it a high wing with twin motors , set up with differential thrust for yaw control on the water .
Puddle Star (4 min 21 sec)
balsa or carbon is online now Find More Posts by balsa or carbon
Old May 24, 2015, 05:36 PM
Petem is online now
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Werribee, Victoria, Australia
Joined Jul 2008
Not bad, that Puddle Star - with more power, more control authority and a better pilot, it could be quite a performer!
Petem is online now Find More Posts by Petem
Old May 24, 2015, 06:31 PM
Joined Aug 2010
I've always been a fan of sarcasm !
Old May 24, 2015, 06:56 PM
Mad_Mike is offline
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
Yeah, +1.
I'd love to be able to fly like that.
Not yet.
I really like the idea of dual motors for yaw but I just want the equivalent of a Giant Delta on a boat platform to see if I like water.
I don't want to spend much time building something we all know will get trashed.
The Slowboat is my favourite right now with the Polaris a VERY close second.
Both have lots of finicky parts though.
I just might put a styrofoam SM hull under the Giant Delta and see what happens!
Old May 24, 2015, 09:34 PM
Joined Aug 2010
Yeah, +1.
Not yet.
Probably the simplest plane to make for flying off water is the SnowBall - a NutBall with floats . I've seen these swim boards ( photo ) at the Dollar Tree Store - might be a good material to use .
Snowball on water pt1 (3 min 18 sec)
Old May 24, 2015, 10:29 PM
Wormboy's Avatar
Joined Jul 2011
Probably the simplest plane to make for flying off water is the SnowBall - a NutBall with floats . I've seen these swim boards ( photo ) at the Dollar Tree Store - might be a good material to use.
Good call B&C, it doesnt get much more simple and robust than that. Even depron would be plenty strong enough since water, although hard on electroncs, is a lot softer and more forgiving on the airframe.
Old May 25, 2015, 08:12 AM
Mad_Mike is offline
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
Well, you've done it again Al!
As much as I dislike the arse dragging attitude of the Nutball, this looks to be what I'm looking for as a first waterplane.
I bet I can improve on it a bit to make it look more like an airplane and maybe get it to fly better.
I'll be checking out that Dollar tree foam floater too but I'd like to try some Depron.
I have lots of CF spars out of the old Bix3 since nobody bought it.
Old May 25, 2015, 11:47 AM
Joined Aug 2010
It's also been done with a delta - if the SnowBall is just too unbearable !
RC float plane flying (1 min 25 sec)
Old May 25, 2015, 12:51 PM
Mad_Mike is offline
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
Even better!
Old May 25, 2015, 01:11 PM
Joined Aug 2010
Even better!
I'll be waiting for the video !
Old May 27, 2015, 04:02 PM
Dave Barrow is online now
Find More Posts by Dave Barrow
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
How about the Judi Seajet. I just ordered a foam kit from birdofplay.
Thread with plans, kit cutting info, pictures and videos-
http://www.rcgroups.com/forums/showthread.php?t=2321902
Dave Barrow is online now Find More Posts by Dave Barrow
Discussion First plane, first flight, plane lost! anyone else? Limetwist Australia 19 Mar 21, 2015 12:09 AM
Discussion Amazing unbeleavable first waterproof coaxial helicopter fly in the water nickden Coaxial Helicopters 16 Apr 24, 2014 07:12 PM
Question best first water plane minimag. floats or gemini ? cmulder Foamies (Kits) 4 Sep 25, 2007 01:07 AM
Yippee! My first water plane Jeff Hartley Waterplanes 1 Jul 12, 2004 01:37 PM
