Old Mar 03, 2015, 12:51 PM
firekosc is offline
Find More Posts by firekosc
Joined Jun 2014
Question
Conversion
Hello.
I have long lurked on the gas forums, though only being an electric modeller myself. Would 1/2A be a good model basis to begin building/flying gas?
firekosc
firekosc is offline Find More Posts by firekosc
Old Mar 03, 2015, 01:21 PM
Jburry is offline
Find More Posts by Jburry
Jburry's Avatar
Canada, NB, Mispec
Joined Feb 2015
Fuel powered models aren't much different from their electric breathern, except for their power source. Flying a 1/2a engine powered model isn't really much different than a similar electric model.
1/2a engines are attractive for someone looking to dabble in engine powered flight as they typically are used with simpler field kit. Little need for electric starters and the like, so the cost of entry is lower. That is balanced by the quirky nature of many of the engines compared to the larger ones.
If you build and fly electric models, a simple 1/2a model won't be much challenge. Build light and straight, learn to operate the engine and fly to your heart's content.
If, however, you're a beginner with little experience flying any aircraft, you might find that the small scale 1/2a planes can be tricky - they respond more to gusts, and get small quickly. Otherwise, a plane's a plane.
Many small electric models are easily converted to glow power - An engine mount, fuel tank and some basic fuel proofing are the crux of it. There're some cool threads here on the topic.
I've always felt that while electric models have merit, they're soul-less appliances compared to the living fire of an IC engine powered model.... But maybe that's just me.
J
Jburry is offline Find More Posts by Jburry
Old Mar 03, 2015, 09:29 PM
PGregory is offline
Find More Posts by PGregory
Now I have to land that thing?
PGregory's Avatar
United States, NY, Poughkeepsie
Joined Apr 2014
Very rewarding flying 1/2A glow or diesel, but I might add you will not have the same throttle control you do with electrics, if you have any control at all. You generally land dead-stick every flight, have to be ready for that eventuality.
PGregory is offline Find More Posts by PGregory
Old Mar 04, 2015, 12:56 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Tampere, Finland
Joined Nov 2004
I was thinking that going for a slightly bigger engine might give you easier starting and setup.
perttime is offline Find More Posts by perttime
Old Mar 04, 2015, 08:45 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
While I still like the little guys, I have found the .15 to .25 size motors very user friendly, and they fly in a bit of wind better than the .049 stuff. The little guys are a bit hard to find, and more finicky, especially the reedies for newbies. They are quite simple and easy to figure out though.
aspeed is offline Find More Posts by aspeed
Old Mar 04, 2015, 12:54 PM
Condor84 is offline
Find More Posts by Condor84
Condor84's Avatar
United States, FL, Hastings
Joined May 2013
A lot of us started off on 1/2a airplanes either before electric flight became practical, or right at the cusp of it. When I learned, if you were serious, you flew gas and started with 1/2a or similar, and electric was something only techy guys or non serious beginners would do; that was the perception at the time at least. I started with 1/2 a, then my next real engine was an OS FS-40 four stroke. Now, go figure, I'm almost exclusively an electric modeler myself. I'd say 1/2a would be an alright choice, because as mentioned, the starting equipment is minimal, and they can be quite easy to set up and get running alright, but at the same time, with certain airframes, if the engine isn't in optimal shape, the engine may not even fly the airplane. The lack of throttle control and dead stick landing with most the 1/2a models and engines may scare some, but it can also be a whole lot of fun in it's own right. As well, just admiring the little jewels that these engines are engineering wise is fun. However, they are considerably noisy, quite messy (be prepared to do a lot of cleanup after words), and noisy in a way that if there's any one within half a mile, they will find you annoying and maybe even unbearable. If you're new to gas, I would actually suggest a .10-.15 size motor and airplane, for the simple advantages that the engines can be less quirky, they tend to be silenced better, and they have good throttle control. That, and while the airplanes for these engines are only a little larger than a 1/2a airplane, that can make a huge difference, especially if you're not used to tracking a very small fast moving object through the sky. 1/2a airplanes can sometimes be hard to follow, especially some of the faster smaller ones. Now, would I steer you away from 1/2a? Not at all, but I'd actually suggest it as a second engine after you've learned on the .10-.15s first.
Condor84 is offline Find More Posts by Condor84
Old Mar 04, 2015, 01:08 PM
MiZer1981 is online now
Find More Posts by MiZer1981
United States, WA, Mt Vernon
Joined Jun 2014
That was my first RC model, scratch built from plans.
I dabbled in control line in the 90s, and more recently free flight 1/2A engines so I was familiar with their operation enough to avoid much frusteration.
MiZer1981 is online now Find More Posts by MiZer1981
Sold Convering - 12 rolls unopened edbu1 Aircraft - General - Miscellaneous (FS/W) 1 Apr 06, 2014 10:27 AM
Question what size motor to convers speed 400 e-plane to glo Thermalin Fuel Plane Talk 4 Aug 01, 2007 11:53 AM
Sold FOR SALE NEW Futaba R149dp PCM 9 channel receiver, 72mhz dual conver. Hi and Lo ch59 charlieb Aircraft - General - Radio Equipment (FS/W) 0 Dec 03, 2006 05:27 PM
Blade convering question cat5 Micro Helis 9 Oct 21, 2005 11:52 AM
Convering for beginners khaoz Beginner Training Area (Aircraft-Electric) 8 Oct 03, 2005 04:25 PM
