Old Jan 25, 2014, 06:34 PM
Joined Jan 2011
Smaller prop gave me higher amps??
I had a 9x6 prop on my Predator Drone with a Turnigy motor that stated 9x6 was the best prop to use. The motor specs are 17.5 amps and 180 watts. I tested the 9x6 with my power meter and got 210 watts and 21 amps. I picked up an 8x6 prop and my watts went up to 300 and amps to about 30. The 8x6 is a much thinner Master Airscrew prop. The 9x6 is a thicker APC - See links.
Shouldn't my power usage hab\ve gone down about 15-20% with the smaller prop?
I realize I am going to need to go to an 8x4, but this test stymied me.
8x6: http://secure.hobbyzone.com/MAS0860G3.html
9x6: http://secure.hobbyzone.com/APC0906P.html
motor: http://hobbyking.com/hobbyking/store...dProduct=36717
bbells is offline Find More Posts by bbells
Old Jan 25, 2014, 07:08 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
I believe there is a large difference in efficiency of the two style of props. You may be just "spinning your wheels" with the MAS. What is the RPM with the two different props on? The MAS may spin at a higher RPM but it may take a lot more power to get it there due to weight/shape/etc.
davidmc36 is online now Find More Posts by davidmc36
Old Jan 25, 2014, 07:45 PM
Joined Jan 2011
That must be it.
Old Jan 26, 2014, 12:40 AM
Georgia
Joined Jun 2007
One of the props referenced is a "pusher prop" ???
chuck75 is offline Find More Posts by chuck75
Old Jan 26, 2014, 03:07 AM
Joined Jan 2011
Yes. Couldn't find a pusher with the right twist and length so I needed to change the rotation of the motor and use a regular prop. Now I will be cutting down the pusher.
Old Jan 26, 2014, 03:19 AM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Being able to reverse rotation with just switching wires means that 'pusher' props are not really necessary - you've already solved that problem. They ARE necessary for glow engines which have a specific rotation direction.
scirocco is online now Find More Posts by scirocco
Old Jan 26, 2014, 10:22 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
As David said, "MAS-Electric Only" props are only good for stirring paint.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 26, 2014, 04:20 PM
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
His link is to a MAS nitro prop.
davecee is offline Find More Posts by davecee
Old Jan 26, 2014, 04:22 PM
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
If the MAS is pulling MORE amps then it's turning LESS rpm, assuming same motor and battery.
Old Jan 26, 2014, 04:49 PM
Profiled Interfractionalist
William A's Avatar
Tacoma,WA USA
Joined Jun 2001
Ditto. Heavy emphasis on "nitro".
William A is offline Find More Posts by William A
Old Jan 26, 2014, 06:04 PM
Toronto Canada
Joined Dec 2002
Nitro props usually have thicker hubs. Because most of the inner portion is stalled statically, that means that they will appear less efficient statically.
That is not necessarily so at Pitch Speed where the full lengths of the blades of the prop are at their maximum lift-drag ratio.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Jan 28, 2014, 04:48 PM
Joined Jan 2011
Thanks for the help.
OK, I changed props and used an APC 9x6 sf and an APC 8x3.8 sf and pretty much the same thing happened. The watts and amps were slightly higher with the smaller prop!
I made a point of trying props that are basically the same design, except one is shorter with less pitch. If I had any hair I would be pulling it out right now.
There is nothing rubbing on the motor. The motor is about 1500kv with a maximum 180 watts and 17.5 amps. I am getting 230 +/- watts and high 20's in amps.
Could this be a caused by my 2 foot battery lead going back to the motor? I'm starting to think I should just limit my throttle so my amps don't go over spec and fly the damn thing with the smaller prop until the motor gives out. Would I get better results if I put my watt meter closer to the motor rather than closer to the battery?
Any help would be appreciated.
Old Jan 28, 2014, 05:19 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Bbells
Something is curious in your results
Try Scorpion Calc freeware (menu propellers)
http://www.rcgroups.com/forums/showthread.php?t=736782
Good for an order of magnitude.
prop #67 APC 8x3.8 SF @ 9000 rpm corresponds to 68W (power at shaft)
prop #121 APC 9x6 SF @ same speed 9000 rpm corresponds to 178W
of course the motor efficiency is different and loading is lowering the rpm
I suggest you to check rpm (tachometer)
Note that power is roughly kp(rpm^3) for a given prop
Louis
Fourdan is offline Find More Posts by Fourdan
Old Jan 28, 2014, 05:29 PM
Joined Jan 2011
Ok, I am going to borrow another watt meter. I will post the results.
Old Jan 28, 2014, 06:14 PM
Joined Jan 2011
Who knows. Maybe my new motor is shorted or something inside.
Joke The Year My Dad Gave Me The BEST GIFT EVER (or so he believed). SSgt Baloo Humor 5 Jan 21, 2014 12:47 PM
Discussion Help me choose a motor & prop for my FPV bird Dauntless Stan FPV Aircraft 3 Oct 02, 2013 08:23 PM
Question Higher KV & Smaller Prop VS. Lower KV and Bigger Prop fnffishcore Power Systems 4 Jan 22, 2013 11:14 PM
Discussion low kv bigger prop vs higher kv smaller prop Twisted Realm 3D Flying 3 Jul 13, 2009 12:01 PM
