Old Nov 21, 2012, 07:01 PM
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Idea
PLD OpenBAC units
I've been trying for the last 8 months to find a manufacturer to take over the production of the BAC units that I have (primarily the BAC-55C and BAC-ESJ6) so, I guess there's not a lot left for me to do other than to Open-Hardware/Source the PLD BAC units.
These will be released under a non-commercial free licence, that is to say that if you want to commercially produce these you will still have to licence the design from me. For hobbiests, it's all open.
The PLD-BAC-55C is the result of over 20 design revisions over 4 years of work. It's not the easiest thing to build due to it using the very small Attiny10 (or 5) microcontroller, which you'll need to program before soldering to the board with a TPI type programmer (not the normal SPI type that you use with most AVRs).
I'll put up the PCB files (Eagle) and firmware code in the coming days.
PLD is offline Find More Posts by PLD
Old Nov 21, 2012, 08:43 PM
JonyEpsilon's Avatar
London, UK
Joined Jan 2009
That's great! I'm sure I, and many others, will learn a lot from studying your battle-tested design. Do you think you might publish the older revisions as well? It would be really interesting to see the evolution of the design.
Jony
JonyEpsilon is offline Find More Posts by JonyEpsilon
Old Nov 21, 2012, 08:50 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Jony,
I'll probably put out a couple of the 'turning point' design revisions, there's about 4 of those, where things were notably changed (usually either because of part supply issues or making it easier to assemble quickly, or optimising part counts).
You can build these by hand, most of the resistors are 0603 size, which while being 'small' isn't as bad as trying to manage 0402 which will drive you insane
Old Nov 21, 2012, 11:19 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Source-code for the BAC55C
Old Nov 22, 2012, 08:55 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
The complete package file is now loaded up on the first-post of this thread, it includes the source and eagle files.
Please note - if you're a commercial entity wanting to produce these BAC units, you will need to licence them from me still. Non-commercial production by fellow DLG'ers is permitted under the BSD and CERN licences as included in the zip file.
Old Nov 23, 2012, 06:01 PM
Just a plane Junkie
Portland, Oregon
Joined May 2002
Very cool! Thanks Paul.
apex is offline Find More Posts by apex
Old Nov 25, 2012, 07:53 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I might release the earlier version of the BAC, using the Tiny13 chip, since it's a lot easier to manage than the T10.
Found Wanted: PLD-BAC-ESJ; Combo BAC switchjack wdwimbish Aircraft - Sailplanes (FS/W) 1 Sep 06, 2012 03:12 PM
Discussion 20% off PLD-BAC-55 Regulator Neil Stainton Hand Launch 6 Jun 07, 2012 07:39 PM
Build Log PROTO - 1S Boost/Regulate/Charge/monitor/switch combo unit by PLD PLD Hand Launch 28 Aug 04, 2011 10:25 AM
New Product PLD 10~150mA 1S lipo charger with USB (PLD-LICH-150) PLD Micro Ready-to-Fly 0 Dec 16, 2010 02:39 AM
New Product PLD 10~150mA 1S lipo charger with USB (PLD-LICH-150) PLD Batteries and Chargers 0 Dec 14, 2010 02:44 AM
