Old Jan 05, 2016, 05:58 PM
minirotor is online now
Find More Posts by minirotor
minirotor's Avatar
QLD Australia
Joined Oct 2009
Buzz VTPR Gliders in Nth QLD
Finially up and gliding.
These are amazing gliders for slow aerobatics;
http://www.rcgroups.com/forums/showt...2#post33639853
minirotor is online now Find More Posts by minirotor
Old Jan 05, 2016, 06:17 PM
kinundrum is offline
Find More Posts by kinundrum
kinundrum's Avatar
Australia, QLD, Gold Coast
Joined May 2008
did you build them or get justin to sent them nearly RTF?
kinundrum is offline Find More Posts by kinundrum
Old Jan 05, 2016, 07:11 PM
Swoopdown is offline
Find More Posts by Swoopdown
C'mon more Energy
Swoopdown's Avatar
Melbourne, Australia
Joined Mar 2005
Good to see Justin managed to make things right.
They look like a stack of fun.
Swoopdown is offline Find More Posts by Swoopdown
Old Jan 05, 2016, 10:32 PM
minirotor's Avatar
QLD Australia
Joined Oct 2009
Hello kinundrum,
They are nearly RTF.
1. Glue wings/joining spars together.
2. Glue wings/ailerons and tail plane/elevator into fusalarge[rudd/elev comes hindged already]
3. Hookup linkage to ailerons[servos/battery-LiFe, already installed]
4. Hook up pull/pull string controls to elev/rudd[you can add the longer elev/rudd control horns if you like 1st]-makes it very twitchy--use lots of expo.
5. Add RX of your choise.
6. Set up the controls and radio as per Justins instructions[He will e-mail you the build/setup instructions after you buy them]
7. Check C of G--and away you go.
Its all seems a bit flippy/floppy--but works fine[its definately not for speed--fast walking/running pace is about flat out--this is for 3D flying, near the stall speed]
Which it does very well.
The control strings do not need to be too tight-just not loose[controls will flutter a bit if they are loose-though thats not really a problem even then]
M
Old Feb 15, 2016, 03:59 PM
minirotor's Avatar
QLD Australia
Joined Oct 2009
Finially got all 6 Buzz gliders flying[not all together in the air yet]
But heres 4 flying;
https://www.dropbox.com/s/phoms97db2...56.52.mp4?dl=0
Lot of lurning to handle them over next year.
Very maneuverable glider--but requires delicate management of airspeed[no motor to pull you out of trouble--LOL]
More info here;
http://www.rcgroups.com/forums/showt...2236074&page=2
M
Sold Hacker Vagabond VTPR glider ORANATOR Aircraft - Sailplanes (FS/W) 4 Nov 25, 2015 10:00 AM
Sold Hacker Vagabond VTPR glider Steve 0 Aircraft - Sailplanes (FS/W) 10 Apr 29, 2015 09:41 AM
For Sale VTPR Glider Kits Available JGAF Aircraft - Sailplanes (FS/W) 8 Oct 02, 2014 02:43 PM
Discussion SoCal VTPR fly-in, May 5th - Temple or Glider Point slope oldscooler Slope 611 Apr 02, 2012 03:39 PM
Alert Hastings Point Camping And Sloping For Brisbane Qld And Nth Nsw Flyers 14FELIX2 Australia 4 Mar 07, 2008 05:12 AM
