Old Sep 28, 2015, 03:34 PM
glouis is offline
Find More Posts by glouis
glouis's Avatar
Ireland, Dublin, Howth
Joined Nov 2008
Help!
piercing holes through sail patches
Hi,
I am building a new set of sails for my son DF65 and I was wondering how do you do the holes in the sails through the reinforcement patches?
thx
glouis is offline Find More Posts by glouis
Old Sep 28, 2015, 04:42 PM
Dick L. is offline
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
I have a soldering/Craft woodburning iron with a pencil tip. Just heat and melt your way through. Seals the edges so no problems. If not - use a nail of suitable size and pliers. Hold over a gas flame until red-hot and press through where you want the holes.
Dick L. is offline Find More Posts by Dick L.
Old Sep 28, 2015, 05:32 PM
glouis is offline
glouis's Avatar
Joined Nov 2008
was tempted in doing that but was afraid that the hole would stretch bigger than the actual nail diameter with the heat no?
Old Sep 28, 2015, 06:41 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
A punch set works too. Found a nice one in the paper craft section of the store. It has a spring in between a punch and a grommet setter.
Or heat up a piece of brass tube. Or a paper clip. Or a nail.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Sep 29, 2015, 03:02 AM
glouis is offline
glouis's Avatar
Joined Nov 2008
thank you for your response - will try the hot nail and see.
Old Sep 29, 2015, 10:14 AM
slotracer577 is offline
Find More Posts by slotracer577
Joined Jan 2006
I use a 1/16 wire heated by a torch. Makes a hole and seals the edge at the same time.
slotracer577 is offline Find More Posts by slotracer577
Old Sep 29, 2015, 11:37 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
A nail might be too big use a hot needle or something that size you can reheat and enlarge if needed but you can't shrink it.
The Tug is offline Find More Posts by The Tug
Old Sep 29, 2015, 12:12 PM
Crunchy Frog is offline
Find More Posts by Crunchy Frog
Crunchy Frog's Avatar
Canada, BC, Victoria
Joined Oct 2012
I've found that a drill works pretty well. It melts the edge around the circle, giving some strength to the hole.
Crunchy Frog is offline Find More Posts by Crunchy Frog
Old Sep 30, 2015, 03:09 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Using the hot wire / hot nail / soldering iron on plastic material causes the material that was in the hole to melt rather than vaporize so it creates a natural welded in eyelet.
mfr02 is offline Find More Posts by mfr02
Discussion Right angle/through hole Male futaba J? hooziewhatsit DIY Electronics 5 Jan 17, 2016 01:24 PM
Discussion Help! Adapting M2 screw to fit through M3 hole foxur Multirotor Beginner 11 Jul 17, 2015 02:29 PM
Question shell hole patches? Jason G Giant Scale Airplanes 7 May 30, 2015 11:51 PM
Question Patch / Repair Holes in Polystyrene BigPaulie Dock Talk 7 Nov 06, 2014 02:30 PM
