Old Aug 27, 2015, 09:17 PM
trmcph01 is offline
Find More Posts by trmcph01
United States, FL, Gainesville
Joined Apr 2015
ZTW 10A BEC / UBEC Question
I was considering getting this with a six channel plane. It looks like you have to use the accessory port of the receiver, does this eliminate one of the available channels for your receiver?
trmcph01 is offline Find More Posts by trmcph01
Old Aug 27, 2015, 09:42 PM
Glacier Girl is online now
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Little confusing post. Is this a one unit esc/bec or a esc and a stand alone bec?
If it's the latter, no, just hook it up with a Y harness to one of your other leads, except the esc of course. Won't loose any open channels that way.
Add on: if again it's the later, you may need to remove the center wire from the servo plug for the esc. That would be if the esc has it's own bec built in. That way the two don't end up fighting each other. Just lift up the tab on the plug, slip out the center wire, and cover the wire end with a piece of heat shrink.
Glacier Girl is online now Find More Posts by Glacier Girl
Old Aug 28, 2015, 02:40 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Assuming you're talking about this, you can connect it to any spare port or, as Glacier Girl has said, Y-lead it to share a port with any other component.
And if your ESC already has a BEC in it, you need to disable its BEC the way that's been mentioned too.
abenn is offline Find More Posts by abenn
Old Aug 28, 2015, 02:04 PM
trmcph01 is offline
Joined Apr 2015
Sorry to be confusing, the ESC I have has a BEC built in. I have had problems with "brown outs" in the past and was hoping this will solve my problem.
Old Aug 28, 2015, 02:06 PM
trmcph01 is offline
Joined Apr 2015
Thanks for all of the input.
Old Aug 28, 2015, 03:16 PM
abenn is offline
Joined Jul 2004
Hopefully it will So just disconnect the ESC's red wire and you're good to go.
Sold spider ztw opto 10a escs jtm_Sea Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2015 06:03 PM
Discussion external Bec or no? Hobbywing 100a with onboard 10a bec flysohigh Power Systems 15 Feb 19, 2015 02:23 AM
Sold MotroFly DM3615(SOLD) with ZTW 70A ESC + ZTW 10 UBEC mhendrix Aircraft - Electric - Power Systems (FS/W) 2 Mar 28, 2014 09:29 PM
For Sale 3x ZTW 12A UBEC (NIB) $28 ea shipped Garret H Aircraft - Electric - Power Systems (FS/W) 1 Sep 25, 2013 10:05 PM
megatech 10A brushed ESC+BEC question peterp1964 Power Systems 2 Dec 04, 2005 12:43 PM
