Old May 17, 2015, 05:42 PM
SupraStar3000 is offline
Find More Posts by SupraStar3000
Joined Sep 2007
VS1100 Ultra Micro FPV range improvement.
Hi, I'm new with FPV and have been flying my Quad with the new Fatshark/Spektrum Ultra Micro FPV (VS1100) system. Everything seems to work great and FPV flying is so immersive, and natural. Very addictive.
My only criticism is the range. Line of sight isn't too bad,... but as soon as an object such as a tree gets between me and the model the picture begins to go.
Does anyone know of any products that are compatible ,..which can help with range.
Regards
Ed
SupraStar3000 is offline Find More Posts by SupraStar3000
Old May 17, 2015, 06:36 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Does that system operate on 5.8GHz? If it does most of the standard FPV antennas and transmitters will be compatible. Also need to know what voltage the transmitter operates on.
Sometimes a better receiver antenna (helical) will solve problems like yours.
RC Man is online now Find More Posts by RC Man
Old May 17, 2015, 10:05 PM
harrison_robert8 is offline
Find More Posts by harrison_robert8
Australia, SA, Oodnadatta
Joined Apr 2015
Regards
Ed
Based on ur Fatshark FPV system,
you can try this, more gains, long range!
http://www.foxtechfpv.com/arkbirdaat...er-p-1918.html
http://www.foxtechfpv.com/foxtech-58...nna-p-187.html
http://www.foxtechfpv.com/58g-16dbi-...nna-p-437.html
Any technical question, you consult with Foxtech customer service!!
harrison_robert8 is offline Find More Posts by harrison_robert8
Old May 18, 2015, 07:00 AM
Joined Sep 2007
Thanks for your help guys. Will take a look at those links.
Yes, this is 5.8GHz.
Not sure how to find the voltage the transmitter operates on, but the camera takes 1S LiPo's.
My problem here is the kit is basically a plug and play system, and I'm not sure it can be upgrade.
Old May 18, 2015, 07:33 AM
United States
Joined Feb 2001
That sounds like itís a good way to get started in FPV and was not designed to be upgraded.
Maybe you should just keep it as is and save up for a larger aircraft that is compatible with all the standard FPV gear. Your receiver will work so you wonít need to upgrade that.
Old May 18, 2015, 08:43 AM
Julezwatts is offline
Find More Posts by Julezwatts
WOT and going nowhere
United States, VA, Charlottesville
Joined Aug 2014
I've replied to your thread on FPVlab.
If you're going to upgrade antennas, nothing compares to VAS antennas.
Julezwatts is offline Find More Posts by Julezwatts
Old May 18, 2015, 01:58 PM
Joined Sep 2007
Really appreciate your response on FPVlab Julezwatts. Going to have a good look now. Thanks
Sold SPEKTRUM VS1100 Ultra Micro FPV System Sixter FPV Equipment (FS/W) 4 Jun 18, 2015 03:08 PM
Discussion FPV range on Phantom 2 with Ibrazy Blue Ultra shabba007 FPV Talk 2 May 17, 2015 06:56 PM
Sold tuned 0.9-1.2G 4ch ultra long range(5km) FPV system gzhou358 FPV Equipment (FS/W) 4 Apr 29, 2015 10:54 AM
Sold SONY 700 TVL FPV Ultra Low Light Mini Camera EFFIO-E CCTV Long wide Range DJI Phantom jmremash FPV Equipment (FS/W) 5 Mar 21, 2015 06:55 PM
