Old Sep 11, 2013, 09:06 AM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by dante1 View Post
You can sell the mainboard and buy another one.
...or adapt your mod to new connector (see wiring diagrams on http://mirumod.tk)
pawelsky is offline Find More Posts by pawelsky
Old Sep 11, 2013, 10:48 AM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
Yup, good point
dante1 is offline Find More Posts by dante1
Old Sep 11, 2013, 04:18 PM
bobtaz13 is offline
Find More Posts by bobtaz13
Joined Sep 2013
Whats the pin out on the new one? Is it the same program? What are the voltages?
bobtaz13 is offline Find More Posts by bobtaz13
Old Sep 11, 2013, 04:54 PM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
http://mirumod.tk/hw/arduino_nano/arduino_nano.php
Old Sep 22, 2013, 12:11 PM
Abbacus is offline
Find More Posts by Abbacus
Joined Jun 2013
Continuous red instead of quick blinking after uploading pilot021.arm on ftp root
Hi everyone
I have successfully installed mirumod with GPS and it works fine with my turnigy 9X.
My problem started when I uploaded pilot021.arm on the root folder using an ftp connection. When I did that the drone did not boot properly, it ended up having a continuous red light on the arduino.
I had to delete pilot021.arm from the root folder to make the drone boot up properly again with mirumod.
Any ideas why this happens?
I have checked Q11 in mirumod's webapage (i.e. My MiruMod's LED flashes as it should when booting, but then stays solid bright. What's wrong?):
- setup mode works just fine
- MiruMod is plugged in correctly. I suppose the fact that it works when pilot021.arm is not on the root folder proves that.
- no loose, broken or disconnected cables going to/from the MiruMod/LevelShifter/Drone plug
- ls -l /tmp - this returns a list of files which does not include at2so.arm.
I would appreciate your assistance!
Yiorgos
Abbacus is offline Find More Posts by Abbacus
Old Sep 22, 2013, 12:48 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Originally Posted by Abbacus View Post
Hi everyone
Yiorgos
Did you do a 'sync' after the upload of pilot021.arm to /data/video?
miru is offline Find More Posts by miru
Old Sep 22, 2013, 01:39 PM
Abbacus is offline
Joined Jun 2013
I was not aware that I had to do a 'sync'. Do I type SYNC at telnet after having uploaded pilot021.arm with ftp?
Old Sep 22, 2013, 01:44 PM
miru is offline
Vista, CA
Joined Feb 2008
Yes, but use lowercase... and do it right after the ftp before you cycle power to the drone.
Old Sep 22, 2013, 02:01 PM
Abbacus is offline
Joined Jun 2013
It worked! Drone boots normally now and arduino lights quick flash as previously. Thank you so much!
Old Sep 22, 2013, 07:50 PM
miru is offline
Vista, CA
Joined Feb 2008
MiruPCB available now
• the solution for a painless implementation of the MiruMod
• small size 0.7” x 1.6” and light weight 3.5 g
• basic configuration does not require wires
• integrated Logic Level Converter and connector for drone
• built in USB connection for software updates and SETUP mode
• auto detection of SETUP mode when USB port is plugged into computer
• serial bridge function for drone
• convenient connector points for GPS, I2C and remote activity LED
Check http://mirumod.tk/hw/mirupcb/mirupcb.php for more information.
Old Sep 23, 2013, 03:06 PM
Abbacus is offline
Joined Jun 2013
Receiver error signal delay MAX value of 8.3sec
Why is there a max limit for this parameter?
I am planning to fly the drone over the sea and I would prefer that it doesn't land if the signal is lost. If it stays in the air I will have some time to think how I can get closer in order to restore the signal. Obviously 8.3 sec is much better than 0sec but I would prefer if I had let's say 60 sec.
What will happen if I define this parameter with values > 8.3 sec?
Old Sep 23, 2013, 04:53 PM
miru is offline
Vista, CA
Joined Feb 2008
You will get a truncated value, which is not what you expect!
The 8.3 seconds come from the loop running at 30 Hz and the erx variable beeing an unsigned char variable (1/30 * 255 = 8.5). You could make the erx variable an unsigned short (u16_t) and change the MERX macro to (u16_t)((double)LOOPHZ*(double)60.0+0.5). Don't use the SL2TIC() macro, it typecasts the result to an unsigned char!
Old Oct 01, 2013, 01:48 AM
Gountled is offline
Find More Posts by Gountled
Joined Mar 2013
Hi MIRU,
which value/line do I need to change in order to increase the delay to 5 seconds?
Do I need to change this line to:
#define S2LTIC(s) (u08_t)((double)LOOPHZ*(double)(5)+0.5)?
Or what do I need to change?
Gountled is offline Find More Posts by Gountled
Old Oct 01, 2013, 09:02 AM
miru is offline
Vista, CA
Joined Feb 2008
Originally Posted by Gountled View Post
Hi MIRU,
NO, please don't! Check line 61:
Code:
#define	MERX		S2LTIC(0.5)
and change it to
Code:
#define	MERX		S2LTIC(5.0)
Old Oct 01, 2013, 09:51 AM
Gountled is offline
Joined Mar 2013
Tranks a Lot!
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
