Old Dec 27, 2013, 11:50 AM
Kauai
Joined Jan 2011
I'm waiting for my kit,and then my building will start.Still on the fence of using the Kk2.1 controller,it might be over my head.Second choice is the Naza m lite which looks to be much easier to program.
Kauaiguy is offline Find More Posts by Kauaiguy
Old Jan 15, 2014, 10:24 AM
United States, FL, Gainesville
Joined Jul 2013
I finished building the frame a week or two ago & my ESC extensions just showed up along with the Kk2.1 FCB yesterday. Now to get it flying this weekend if I can! I don't have the programmer yet for the connections to the computer!
FloridaAKM is offline Find More Posts by FloridaAKM
Old Jan 15, 2014, 01:53 PM
United States, NY, Albany
Joined Jan 2013
Make sure the blades are not installed when you power it up. Unless you changed out the ESCs I don't think the KK2 board will drive the bumblebee ESCs. Unless BumbleBee ESCs are connected to a BumbleBee FC, they will fire up at full speed and not respond to controls. This usually results in killing everything in the room. Don't ask me how I know this.
teamhairball is offline Find More Posts by teamhairball
Old Jan 15, 2014, 02:39 PM
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Look Out
You can say that again.. I got lucky as hell as I had not put on the props scared me to death thinking what would have happened. ditch the stock esc's and get some 18-20amp ones from HK pretty cheap and you will be fine.
tallflyer is online now Find More Posts by tallflyer
Latest blog entry: New GoPro Hero3+ Black Edition
Old Jan 15, 2014, 03:40 PM
Joined Jan 2013
Let me know if you find an ESC that will fit under the little hoods. I would like to change the FC to maybe a Naza but don't want ESCs zip tied to the booms.
Old Jan 15, 2014, 09:03 PM
Joined Jul 2013
To clarify things, the Bumble Bee kit was only the frame, the original motors, nothing else. I originally put 4 Turnigy AE 25 ESCs in the arms, HK main power connection board to connect all the ESC's, a HK FCB ver 3 Atmega 328PA (didn't know any better @ the time) & a Turnigy 9X Tx/ Rx radio system. Tomorrow, I wil take the blades off & power her up to see what she does. The receiver & the FCB are stuck to the upper cf board with 3M double sided tape, since there was no way to use plastic stand offs. If the HK multi rotor board won't fly, the KK2v 1 is the next board to try out. Which programming tool do I need to connect the KK2v1 or a MultiWii 328P Flight Controller w/FTDI & DSM2 Port ( yes, I got one of those too in the armory) to my computer to set up all the things that need tweeking. I am still runnng Windows XP Pro. Thanks in advance!
Old Jan 16, 2014, 08:31 PM
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
I have a Bumble Bee 450 kit that I use a KK v5.5 controller.
It took a while to get it trimmed out but once I did it flew pretty good. That was until I let it get into the sun and it came down on an angle and a little hot.
The first pic is my original aluminum frame that folded up on landing but didn't even break a prop.
The second pic is my new fiberglass frame. Only took me a day to transfer the components from one frame to another. I will hopefully "maiden" the new frame this weekend.
I use a FlySky 9x transmitter and receiver which does a great job.
Eagle202 is offline Find More Posts by Eagle202
Old Jan 22, 2014, 05:56 AM
RC
kendive's Avatar
USA
Joined Jan 2004
Nope there still out there. Here's mine BB550. Going to start on the TBS Disc Pro next
kendive is offline Find More Posts by kendive
Old May 06, 2014, 01:41 PM
Canada, ON, Mississauga
Joined Apr 2006
BBB is square shaped alignment for motors, 2 at front and 2 at rear; but HK recommended V3 of KK board which is Diamond shape, Front, left right, rear, is there a toggle jumper to make the board working for BBB?
modelerchina is offline Find More Posts by modelerchina
Old Jun 03, 2014, 04:31 PM
Joined Apr 2006
can someone recommend a propeller upgrade for bbb
Build Log Bob Starr Bumble Bee ---video added--- AJWoods Scratchbuilt Indoor and Micro Models 36 Aug 14, 2013 11:58 AM
Bumble Bee - It's CUTE !! ChrisP Parkflyers 26 Jul 19, 2006 05:07 PM
Hobby-Lobby Bumble Bee ratman Parkflyers 3 Jun 12, 2002 06:42 PM
Hobby Lobby Bumble Bee Twin Tom Smith Foamies (Kits) 12 May 10, 2002 12:23 PM
Hobby Lobby Bumble Bee ? Tom Smith Parkflyers 1 May 06, 2002 04:34 PM
