Old Sep 18, 2009, 01:48 PM
León (Spain)
Joined Jul 2009
Help!
Easy plane to learn to fly on EPP
Hi all,
I have here 4 sheets of 10mm EPP and i want to do a simple plane easy to fly, i destroyed 3 planes on depron and i buyed some sheets of EPP to test it. I made a plane like USAF UFO and i have it here waiting to fly, but the wheater is windy and rain... and i have time to make another plane
I´m sure there are a lot of good epp planes to learn to fly!!
Best regards,
Javier
mindpanic is offline Find More Posts by mindpanic
Old Sep 18, 2009, 03:48 PM
León (Spain)
Joined Jul 2009
:_(
Old Sep 18, 2009, 04:32 PM
A&P Mechanic
may-day's Avatar
San Antonio
Joined Mar 2005
Mindpanic there are dozens of great designs to choose from. look into the scratchbuild plans sticky. Pick the one with the least amount of pieces to assemble and build it. Build the simple delta or the smart dart. I would then move onto conventional aircraft like the blue baby or other trainer style plane with main wings and an emmpenage.
hope this helps.
Dave
may-day is offline Find More Posts by may-day
Old Sep 19, 2009, 08:50 AM
BANG IT!!!
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Look up Tall Flyers SloFly, simple design, all 9 or 10mm constructions and great detailed build videos.
DaOldGuy is offline Find More Posts by DaOldGuy
Old Sep 19, 2009, 10:56 AM
Alberta, Canada
dart and nutball
dean_85 is offline Find More Posts by dean_85
Old Sep 19, 2009, 08:51 PM
Lost but making good time
Joined Nov 2008
Mindpanic,
What do you have besides Epp foam? Motor, servos, esc, receiver, carbon rod etc.
28" superslofly is an excellent plane to learn with. Go to WWW.slofly.com, look for build thread. Yak 55 by Leadfeather, also a fine easy to build and fly plane ( leadfeather's build log on this site). I have them both hanging on my wall and fly them both once a week.
Regards,
Hankg
hankg is offline Find More Posts by hankg
Old Sep 19, 2009, 10:01 PM
Alberta, Canada
Originally Posted by hankg
Mindpanic,
Regards,
Hankg
Hank, if you had to choose just one to fly, which one and why?
Old Sep 20, 2009, 09:33 AM
León (Spain)
Joined Jul 2009
Thanks to all,
I have here this motor and etc..:
- Turnigy CDROM C2822 1400kv
- Lightmax 3s 500mah 20C Lipo (x2)
- 18A ESC (hobbycity)
- BL-2826/6 2200kv
- 30A ESC
- 3s And 2s lipos wich can propocionate 30A aprox.
- 8gr micro servo (x2)
- 3,7gr micro servo (x3)
Best regards,
Javier
Old Sep 20, 2009, 10:33 AM
Joined Nov 2008
mindpanic,
I learned to fly by flying the 28" superslo from www.slofly.com. Now I fly the Yak 55 more than any other plane. I still love the superslo though. it literally floats along if you have a very still day.
Regards,
Hankg
Old Sep 20, 2009, 12:43 PM
Joined Nov 2008
mindpanic,
Sorry, I had to end my thread before i wanted to....Both the superslo and the Yak55 are made to come in with an all up weight of about 7 oz. I use a Blue Wonder 22x4mm x1500Kv motor with a 15 milliamp esc. Three hxt900 servos and a 500 milliamp or less battery 11.2volts. my prop is an 8x4 but a friend uses a 9x4 and a battery with two cells in series. if you should decide on the superslo,I have modified mine somewhat with shock spars, similar to the yak55 and do not cut in the servos.
These planes are not made for speed. They are made to fly at slow to moderate speeds and they will do hovers, rolls, etc. I usually fly in a space 120' in radius and 50-75' elevation. I try for precision rather than speed.
Regards,
Hankg
Discussion which plane to learn aileron controls on? goin down Parkflyers 13 Oct 23, 2006 01:51 PM
Flying 3d plane help learn to fly micro heli? KillerCut Micro Helis 10 Mar 27, 2005 11:45 PM
Easy Way to Learn to Fly PoudreDerf Micro Helis 8 Oct 10, 2004 04:35 PM
Could I learn to fly on this: RTF Ikarus Fun Piccolo? Subysouth Micro Helis 11 Mar 04, 2004 11:49 AM
What is the best foam flying wing to learn to fly on? ZackG Beginner Training Area (Aircraft-Electric) 9 Oct 07, 2003 03:21 PM
