Old Aug 08, 2014, 06:20 AM
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Originally Posted by Herrsavage View Post
So I - a relative beginner - just smashed up my Delta Ray when my radio lost contact.. In it went. And now I need a new plane.., and am considering the AXN. So I have a few questions:
1.) Will it ever be in stock again in the EU warehouse? If so, when?
2.) What's a good list of stuff to order? Not overboard - just the basics I'm likely to need in addition to the plane itself. I need batteries too. Would buy two lipos...
3.) Can the AXN do decent rolls and acrobatics?
4.) Does it need a ton of space to fly in? I have a limited area to fly in. The Delta Ray never stalls and turns on a dime(trees...), and is also easy to land.. Can you fly the AXN in an area of somewhat limited space? (say, 100 x 65 yds, kind of.., with two or three trees here and there.. But a big open 75 x 35 yd. stretch to land in...)
Thanks.
AXN is a glider and can be quick. I am not sure it will be the best for your flight area. Try something a little slower and floaty. Maybe the fun cub copy or the foam old timer thing. May be better for your space and learning curve.
Try one of these:
http://www.hobbyking.com/hobbyking/s...00mm_PNF_.html
http://www.hobbyking.com/hobbyking/s...otor_ARF_.html
http://www.hobbyking.com/hobbyking/s...05mm_PNF_.html
mutha is offline Find More Posts by mutha
Old Aug 08, 2014, 08:56 AM
Callsign: Zulu
Stuka_99's Avatar
Somewhere in the skies!
Joined Feb 2011
The way this lands may surprise a lot of folks. Heck I was surprised at how far this plane glided without power on my first landings. Had to turn around a couple of times before I got the timing right. So for a small space for the first time, a big fat NO lol.
Stuka_99 is offline Find More Posts by Stuka_99
Old Aug 08, 2014, 01:18 PM
Head in the clouds
nascar1929's Avatar
United States, NC, Gastonia
Joined Jan 2012
Thanks.
The AXN is my first and only plane. It was easy to put together and flies nicely. I have flown mine about 2 dozen times now and no crashes......yet! You can do rolls, loops and even inverted with it. You don't need a huge area to fly it, but to see it's full potential, it's nice to be able to let it stretch it's wings and cruise around if you have a larger space to do so.
I'm sure there will be other suggestions on what to buy, but this has worked for me so far with no issues.
I bought the PNP (motor only) version and added the following:
Servo's: Bought 8 since they were so cheap http://www.hobbyking.com/hobbyking/s...Search=hk15178
Colet Adapter: Bought 2 to have a spare http://www.hobbyking.com/hobbyking/s...?strSearch=3mm colet
Prop: Bought 3 to have a few spares http://www.hobbyking.com/hobbyking/s...?strSearch=tgs 6x4e
Battery: Have 5 now, but 2 would be a good start http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
As for the ESC, I already had a 40A laying around and used it. I would recommend getting at least a 30A as others suggest if you don't already have one lying around.
Hope this helps
nascar1929 is offline Find More Posts by nascar1929
Old Aug 09, 2014, 08:18 AM
Germany, BY, M
Joined Jul 2013
I agree to everything you wrote!
Keep in mind you have expieriences as a heli pilot.
In my opinion the AXN is more a beginner with expieriences to advanced plane.
Not for a newcomer to RC flying.
SilbernerSurfer is online now Find More Posts by SilbernerSurfer
Old Aug 09, 2014, 09:53 PM
United States, TX, Fort Worth
Joined Jan 2012
This is a great plane. It was my first plane and took quite a beating, but continues to fly. You really can't go wrong.
I'm at the point where the body just can't be repaired anymore.. I need to purchase a new hull soon. Here's the latest picture of mine with my brother holding it:
dangerz is offline Find More Posts by dangerz
Old Aug 11, 2014, 05:17 PM
United States, CA, SF
Joined Jun 2014
Originally Posted by area51nz View Post
I've been flying the freedom glider, (it has a motor) its pretty close. And now started to customise the Discus 2CT with what technical specs I can find on the AXN.. Its not right yet but getting closer.
I'm a novice (2 months in RC); so a lot of the technical settings are going right over my head. I'm building up an AXN floater-jet and want to practice with the Discus 2CT in aerofly. If you have any screenshots of your settings -- or if there is a way to transfer your file -- I would GREATLY appreciate it! Thanks.
MK500 is offline Find More Posts by MK500
Old Aug 11, 2014, 07:00 PM
crash expert
New Zealand, Canterbury, Christchurch
Joined Apr 2014
what is your tx?
felixx is offline Find More Posts by felixx
Old Aug 14, 2014, 09:04 AM
CaptainPasty's Avatar
United Kingdom, England, Plymouth
Joined Aug 2012
Here's mine with a few views from the gopro
CaptainPasty is offline Find More Posts by CaptainPasty
