Old Dec 28, 2012, 08:32 AM
Australia, NSW, Bankstown
Joined Jul 2012
ESC wires cooked
Hi there,
i would like to know if anyone had the same problem as me in regards to a new Turnigy TrackStar 1/10th Scale 60A ESC i had to replace on my HPI Porsche 911 GT3 as the original ESC failed and the wires keep melting at the ends where they connect together, so i keep soldering them back on
is there too much current flowing through those wires or whats going on???
HELP
lancaster1945 is offline Find More Posts by lancaster1945
Old Dec 28, 2012, 09:13 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
What motor? What gearing? What battery? It's either a cold solder joint, or you're pulling too many amps through the wire.
wparsons is offline Find More Posts by wparsons
Old Dec 29, 2012, 05:10 AM
Joined Jul 2012
5900kv brushless motor, 90/32 gearing and 4000mah LIPO battery
Old Dec 29, 2012, 08:01 AM
LeszekJ's Avatar
Poland
Joined Nov 2010
Where exactly?
At the ESC, at the connectors (3.5 mm bullets), at the motor?
BTW what do you mean writing @HK: "it cooked the hell out of my motor wires conected to the ESC wires also keeps coming loose everytime from each other"?
LeszekJ is offline Find More Posts by LeszekJ
Old Dec 29, 2012, 08:06 PM
Joined Jul 2012
esc
Description: my new wiresnew wires
Old Dec 30, 2012, 08:31 AM
LeszekJ's Avatar
Poland
Joined Nov 2010
I lost somewhere my magnifying glass and I'm not quite sure what your tiny picture presents but I bet on a bad soldering or connector mismatch.
Old Dec 31, 2012, 08:41 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Not too familiar with that car, but a 32T pinion sounds very large for a 5900kv motor... how were the motor temps?
Old Jan 14, 2013, 02:40 AM
Joined Jul 2012
it gets quite hot but ok to run.
Old Jan 14, 2013, 09:02 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Define "quite hot, but ok to run"... sounds like it's too hot, but not quite into thermal shut down on the ESC?
In any case, it's either cold solder joints (or crappy solder), or you're pulling more amps than the connectors can handle. I would remove all the old solder and solder it all back together with high quality silver solder. If that doesn't fix it you'll either have to drop a few teeth on the pinion to keep temps down, or get connectors capable of handling more amps.
Discussion What is the right wire for extending ESC wires to motors? armanm Multirotor Electronics 3 Sep 01, 2012 09:13 AM
Cooked ESC AussieParkflyer Parkflyers 14 Jan 14, 2002 03:47 AM
Could my Astro 010 cook my ESC? mumblety-peg Power Systems 5 Jul 21, 2001 11:52 AM
Astro 010 question...esc is cooked David Hogue Power Systems 3 Jul 02, 2001 02:13 PM
Sky Scooter Pro - wet ESC - cooked? buteo Foamies (Kits) 5 May 23, 2001 08:24 AM
