Old Dec 17, 2013, 09:19 AM
Birmingham, AL
Joined Sep 2003
Canopy Magnets
I would like to use some rare earth magnets to secure the canopy to the fuse on a phoenix K8B 3500. This would make cockpit access easier and avoid using the two bolts to secure the canopy.
What are the best size to use? I am afraid of going too strong & not being able to remove the canopy easily, or too small and not having the canopy secured.
Also should they be installed so the magnets slide apart during canopy removal or directly separate from each other? Or does it matter?
Appreciate any advice.
sleep4 is offline Find More Posts by sleep4
Old Dec 18, 2013, 07:25 AM
Peter V's Avatar
Joined Nov 2008
magnets
Hello Sleep,
in the Netherlands there are magnets to buy which are used in corsages, those flowerthings you wear during weddings on your jacket.
Peter V is offline Find More Posts by Peter V
Old Dec 19, 2013, 04:49 PM
slopemeno's Avatar
Joined Jan 2003
I've used magnets for canopies a couple of times. The 3/8" rare-earth magnets have plenty of holding power. If you use a pin to secure the front of the canopy, two of the 3/8"magnets will hold the rear fine. To open, hook a fingernail under the rear of the canopy and lift.
I usually build a small "shelf" in the fuselage for that side. I put a piece of wax paper or drop-cloth plastic over the magnet, apply the other magnet, apply a blob of E-6000 glue to the back of the magnet, and close the canopy. Wait 24-48 hours for the E-6000 to cure, then try opening your canopy.
I use E-6000 or Goop for adhesive, since it stays flexible for years, and holds the magents really well.
slopemeno is offline Find More Posts by slopemeno
Old Dec 19, 2013, 07:06 PM
aeronca11AC's Avatar
Kirkland, WA
Joined Sep 2007
Harbor Freight has some at a cheap price....
http://www.harborfreight.com/10-piec...ets-67488.html
aeronca11AC is offline Find More Posts by aeronca11AC
Old Dec 25, 2013, 10:28 PM
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
http://www.kjmagnetics.com/categories.asp Huge variety of sizes and shapes.
The slide release idea is interesting. Sure would make removal easier. I've pulled the magnet/adhesive out a couple times in foam planes with a direct pull installation.
Figure out which side is which before you glue them in....it sucks to glue them in only to find that they repel each other! (yeah, I've done that ) Slopemeno's idea of installing them while stuck together would prevent that issue. I sand the back & sides of the magnets with 100g to improve adhesion.
JimZinVT is online now Find More Posts by JimZinVT
Other Ways For Mounting Canopy-Magnets??? Minimole Micro Helis 10 Mar 24, 2005 04:42 PM
Alert GWS FORMOSA's Canopy "MAGNET" hold down! guapoman2000 GWS (Grand Wing Servo) 16 Oct 23, 2004 12:20 AM
TwinJet canopy fastening. Magnet? Downwind3Zero Foamies (Kits) 2 Dec 08, 2003 03:05 PM
TwinJet canopy fastening-magnet? Downwind3Zero Radios 4 Dec 08, 2003 11:39 AM
Small magnets for canopy hatches Kiwi Bob Parkflyers 19 Jan 24, 2003 12:29 AM
