Old Dec 31, 2012, 09:09 AM
rogenstein1983's Avatar
Joined Feb 2012
any one building scratch built micro butterflys with deltang rx52m
Hay, is anyone building scratch built versions of the micro butterfly useing deltang rx52m or similar Auw being around 3 g or less just want to see other people's idears or finished models although maybe a cook up sometime
rogenstein1983 is offline Find More Posts by rogenstein1983
Latest blog entry: Stevens Aero FlyBaby bipe
Old Dec 31, 2012, 09:17 AM
Joined Feb 2012
Oh yeah durabatics foam carbon fiber fuse and Plantraco motor and prop deltang rx52m and a nano actuator glue used was uhu por, the foam safe one ,wing span is 3.5inch, one with an elevator next and maybe a biplane
Old Dec 31, 2012, 12:27 PM
RIP Sheba :(
Robster's Avatar
Brentwood, CA
Joined Nov 2002
This is the same exact gear that I'm using in my Couch Flyer. It's nice having a sub 3 gram plane with RET. The RX52M really drives the NanoActs nicely! I just ordered 2 more RX52M's .
Rob
Robster is offline Find More Posts by Robster
Old Dec 31, 2012, 03:16 PM
Joined Feb 2012
micro flyers
Thay are really good rx,s I found the actuators much more responsive to, I'm currently building a lrf with same component but Plantraco GB05 instead hopefully will be good, using durabatics again and carbon fiber
Old Dec 31, 2012, 03:26 PM
Joined Feb 2012
micro planes
Ment to say you should put up a pick id like yo see it
Old Dec 31, 2012, 05:05 PM
Joined Feb 2012
just checked your planes
Just looked at your page robster and love the lrf with the triangular wings might try that really small
Old Jan 01, 2013, 12:25 AM
RIP Sheba :(
Robster's Avatar
Brentwood, CA
Joined Nov 2002
Looking forward to your builds Rogenstein! Yeah, the little Dart lrf is a good flyer. My cat killed the purple one, but the blue one still flies .
Old Jan 13, 2013, 12:05 PM
Joined Feb 2012
nearly there!!
Rare evening of freedom and I'm nearly done with my latest lrf deltang rx52m and Plantraco components for the rest actuator and prop and motor
Old Jan 13, 2013, 06:38 PM
RIP Sheba :(
Robster's Avatar
Brentwood, CA
Joined Nov 2002
Very nice! Are you going to put an elevator on it?
Rob
Old Jan 14, 2013, 02:28 AM
UK
Joined Aug 2000
Nice. Lots of wing area. Should fly slow. I assume the wing incidences are adjustable?
Regards, David.
David T is offline Find More Posts by David T
Old Jan 14, 2013, 07:41 AM
Joined Feb 2012
It didn't fly to well I had to move the center of gravity forward lots and in the process managed to mangle a wing so converted it to a single wing ,flys really well, will be getting another rx52m when my pocket permits and starting fresh with elevator and pretty much same design oh well rookie mistakes
Old Jan 14, 2013, 08:35 PM
RIP Sheba :(
Robster's Avatar
Brentwood, CA
Joined Nov 2002
You can try different wing configurations on the same fuselage. Where did you get the little plastic carbon rod joining bits for the wing posts? They look like Carbon Butterfly bits.
Keep up the good work!
Rob
Old Jan 14, 2013, 08:52 PM
RIP Sheba :(
Robster's Avatar
Brentwood, CA
Joined Nov 2002
Having said that, a larger area wing with longer span and chord may make that a real nice floater - that GB05 prop/gearbox won't even flinch. I never had luck either with biplane configurations on these little planes, just too draggy I think...
Rob
Old Jan 14, 2013, 10:42 PM
Carbondale PA
Joined Aug 2005
I am happy to see that you guys are having fun with the Micro Butterfly! I designed the model for Plantraco and haven't tried it with the great DT line of receivers yet.
Nice work.
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
Latest blog entry: Micro Laser 3D
Old Jan 15, 2013, 03:15 AM
Joined Feb 2012
Rob
You have a keen eye there robster, yes thay are infact from the ikara butterfly a while ago I managed to mash a carbon butterfly wing and replaced it with an ikara butterfly wing,and of course saved the tiny bits of plastic that where on broken wing as I've never found them to purchase online, I could tell I'm not far off I don't know if it needs bigger wings, as I've looked online and seen people have had success keeping with in the measurements of the original livingroom butterfly I think my problem was cog was to far back and some how was creating to much drag, I may have to have another go with this spare Plantraco rx I have although totally in love with the fantastic rx52m there perfect but cash flow is a problem for another week or to, would much rather the rx52m
Discussion Scratch built (Super advanced) high alfa ultra micro jet. crispy1074 Pusher Prop Jet Models 1 May 19, 2012 02:13 PM
Build Log Scratch Built M100 Micro Plane sweeteye Scratchbuilt Indoor and Micro Models 6 May 10, 2012 10:42 PM
Wanted Any one want an Art hobby glider built for them? Lammergier Aircraft - Sailplanes (FS/W) 2 Mar 02, 2012 05:47 PM
New Product DelTang Rx51 DSM2 Ultra Micro Actuator Receiver (Dsm 2 carbon butterfly RX swap out) richos Scratchbuilt Indoor and Micro Models 27 Jan 26, 2012 07:45 AM
Sold Custom scratch built, one off Micro SJ-70 EDF jet ghostmechanic Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Jun 03, 2010 11:07 PM
