Old Jul 06, 2012, 06:26 PM
United States, VA, Ashburn
Joined Apr 2012
Question
prop switch!
Hey I have a park 450 and I need a prop with good power for 3D but staying within 30 amps. Eflite suggests a 12x6 for a 1020 kv, and my motor is 890 kv. Could I use a 14x6 or a 12x7 or 8 because of the lower kv?
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Jul 06, 2012, 07:00 PM
elfwreck's Avatar
United States, CA, Oakland
Joined Dec 2002
Hey now,
Short answer. No.
Longer answer. Still mostly no. The lower Kv motor is designed to be a lower amp motor. Even a 12-6 is a bit over the top for it. It really wants nothing bigger than an 11-5 prop. That'll take up about as far as is safe for the motor generally speaking. If you use a 14-?? Prop you'll likely smoke the motor soon enough.
That said if you're really doing 3D with it and not just jamming the sticks around at speed you could get away with a 12-6 for the very short full throttle bursts used in propper 3D flight.
If this so t do it for you get a bigger motor.
RobII
elfwreck is offline Find More Posts by elfwreck
Old Jul 06, 2012, 07:06 PM
Joined Apr 2012
Originally Posted by elfwreck View Post
Hey now,
Short answer. No.
RobII
Oh. I was using an 11x 5.5 before so I think a 12x6 would be ok
Old Jul 06, 2012, 07:27 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
The 1020Kv motor is a Park 480, which is bigger and heavier than the 890Kv Park 450. Their prop ranges will be about the same for a given input voltage due to the size difference.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Jul 07, 2012, 02:34 AM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
That's only a 72g motor.. you must be joking talking about a 14" prop on it
The motor is only rated for 18A burst: http://www.channel4models.com/e-flit...tor-890kv.html On 3cells to stay anywhere near 18A you need to limit yourself to an 11" prop; the one you are using must be right on the limit.
Bottom line is you should be able to tell from the amp draw how close to the limit the motor is. You are the best one placed to tell that because you have the motor If you are already at or over 18A then you don't have any headroom for a larger prop.
The 12x6 prop listed for this motor will most likely be for two cell operation. On two cells you could probably push to 13x6.5 prop
BTW.. where did you get the 30A figure from
Steve
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jul 07, 2012, 08:46 AM
Joined Apr 2012
My Esc rating.
Old Jul 07, 2012, 10:37 AM
Aberdeen
Joined Mar 2006
Originally Posted by RCAddict16 View Post
My Esc rating.
That wont help with a motor that's only safe for 18A burst. What amps is it pulling with the 11x5.5 prop?
Old Jul 07, 2012, 10:40 AM
Lost but making good time
Joined Nov 2008
RC,
Have you ever used this program to determine prop size given battery, esc and motor specs? Not as good as a wattmeter but it is surprisingly accurate.
http://www.adamone.rchomepage.com/calc_motor.htm
Check it out and play around with it...you won't have some of the specs but you should be able to come up with cell capacity, number of cells in series, max esc amps, Kv, max motor current, motor weight and prop specs. It gives you a lot of information on motor amps versus prop specs.
Regards,
Hankg
hankg is offline Find More Posts by hankg
Discussion 9x Switch Error (Switches in the correct positions) mkirby Radios 7 Jun 25, 2012 03:45 PM
Question warbird to 3D-er prop switch RCAddict16 Electric Plane Talk 1 Jun 02, 2012 08:22 AM
Switching 10x8 prop on Beaver to 10x4.7 LESLIEx317537 Parkflyers 7 Dec 06, 2002 11:19 AM
Tractor prop to pusher prop--do I need to switch motor leads? daveh Beginner Training Area (Aircraft-Electric) 5 Jan 03, 2002 09:11 AM
mother of pearl! .... switched props tic High Performance 7 Aug 06, 2001 08:58 PM
