Old Yesterday, 03:38 PM
come to butthead
NOTAR 600's Avatar
Central Ohio
Joined Nov 2007
Originally Posted by gooniac33 View Post
I agree that they were powerhouses!! But....they were no where near as big as the afterburner on the mig-25 and mig-31....
True......not as big.
NOTAR 600 is offline Find More Posts by NOTAR 600
Old Yesterday, 03:44 PM
come to butthead
NOTAR 600's Avatar
Central Ohio
Joined Nov 2007
Originally Posted by drone19730602 View Post
Hey Notar.....you planning on doing a custom paint job ?
Seems as if you have something up your sleeve for this air frame?
Hoping can make it light and fast on 4S. Probably wearing fluorescent yellow and red.
Old Yesterday, 05:35 PM
What Goes Up...Must Come Down
abjets's Avatar
United States, NC, Oak Island
Joined Jan 2013
Originally Posted by Joe 1320 View Post
I was looking at that too. First time I saw that fan, the other Haoye variants that I saw were 6 or 7 blades. I wonder if this is brand new? That rotor would be the answer for the weak JPower 5 blade rotor. The Haoye 6 blade fan takes a little bit of modding to work, the 7 blade is quite an amp hog, this might be a direct replacement.
And easier to clock/balance with the fan adapter...probably won't fit a stock motor shaft...maybe a Don's Wicked! On 4S... interesting
abjets is online now Find More Posts by abjets
Latest blog entry: SA F-18 50MM Build
Old Yesterday, 08:30 PM
United States, OH, Mt Vernon
Joined Nov 2010
Anyone know what the Cg is on the A6 intruder. What is specified in the manual is way to tail heavy.
00Smurf is online now Find More Posts by 00Smurf
Old Yesterday, 08:43 PM
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
Cg on my A6 is about 127mm from the intake and not 139, there is a panel line behind the cockpit and near where the wing joins into the fuse my cg is slightly in front of the panel line. I have the stock version and have always flown mine with a 45C 850mah lipo. My only issue was that this was my first 50mm edf and I never roughed out the wings or the fuse to get the paint off before I glued it together. First flight was going good after I trimmed it and then tried to do a roll while at WOT and the sucker spiralled out of control. Right wing came off due to the paint being left on. Luckily the only damage was the nose getting slightly crunched.
nom is online now Find More Posts by nom
Old Yesterday, 10:24 PM
come to butthead
NOTAR 600's Avatar
Central Ohio
Joined Nov 2007
Please help.......I need a link to the most commonly used 50mm six blade fan, as I'm not sure what brand to look for.
***edit: Okay, guess it's the Haoye. I found this.........http://www.rcgroups.com/forums/showp...postcount=9317
Old Today, 02:06 AM
Vienna, Austria
Joined Apr 2007
6-blade Haoye at HK
http://www.hobbyking.com/hobbyking/s...inch_50mm.html
mopetista is offline Find More Posts by mopetista
Old Today, 04:26 AM
come to butthead
NOTAR 600's Avatar
Central Ohio
Joined Nov 2007
Cool thank you!
Old Today, 09:35 AM
FireHawx
FireHawx's Avatar
United States, FL, Jacksonville
Joined Oct 2011
Also in the US at ToySonic. Good place to buy from.
FireHawx is offline Find More Posts by FireHawx
Old Today, 03:43 PM
Norway
Joined Dec 2007
Originally Posted by mopetista View Post
This is the old Haoye HY003-00102-6BP
http://www.haoyemodel.com/product_de...eId=23&id=1114
I was asking about the new one HY003-00603-5B-5B
http://www.haoyemodel.com/product_de...eId=23&id=1146
If it's some thing similar to the Kyosho it's capable of +700g thrust
(past Dr.mad thrust) and 20g less weight and capable of almost 200km/h
teoretical ... (measured efflux +50m/s).
I prefer Haoye's HY003-00201-6BP it's a 6 blade fan and with some mod
it's pretty quit and a lot of thrust on 4S (Kv~5000) a bit too big for SkyAngels
may be (It does not have the speed like Kyosho DF-55 on 4S)
FLOEY is offline Find More Posts by FLOEY
Old Today, 09:13 PM
abjets's Avatar
Joined Jan 2013
I thought the KY DF-55 melted on 4S with all of the plastic...or was that the KY DF-45???
Discussion Adelaide & SA flying & chat #2 Zootster Australia 20734 Today 09:39 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
