Old Jul 19, 2010, 08:03 PM
Joined Dec 2009
ar500 OR AR6100 for the E-Flight Alpha 450
Which receiver would you guys go with for this model? Would I relistically use the range of the ar500?
Also what Lipo's other then Horizon are compatible with the EC3 connector that I assume comes along with the Alpha plug and play?
jedi391 is offline Find More Posts by jedi391
Old Jul 20, 2010, 12:17 AM
USA, MO, saxs
Joined Jun 2010
recommend ar500, full range receiver, also can be used for other models
bk3rc is offline Find More Posts by bk3rc
Old Jul 20, 2010, 05:52 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
If you are looking to buy lipo that already come with the EC3 connector you are seriously limiting yourself with battery.
If these EC3 connectors is what you have then simply buy a bag of ec3 connectors and when you buy new battery do not bother with the connector and simply replace them with yours.
Most hobbiest with replace the stock connectors with their fav. brand.
freechip is online now Find More Posts by freechip
Old Jul 20, 2010, 09:08 AM
Just having fun
Fredriksson's Avatar
United States, KY, Hopkinsville
Joined Feb 2008
For the receiver it depends on what you want the plane to do. The Alpha has 2 servos for the ailerons. The AR500, while being full range, does not have true 6 channels. The two aileron connections are really just like a Y-harness. However, the AR6100 has 6 full channels so you can program in flapperons or spoilerons if you wanted. On a high wing tricycle like the Alpha I like to use flapperons and put both ailerons down on landings.
The Alpha is not so large that you will be going out of the range of the AR6100. If it were my plane I would go with the AR6100 so that I would have the option of flapperons. If I just had to have full range I would go with the AR6200.
As for LiPo's the answers you have already received are correct. All of my planes are set up to use Dean's connectors. When I buy LiPo's I just remove whatever connector is on the LiPo (one lead at a time so as not to short out the LiPo accidently) and solder on a Dean's connector.
Freddy
Fredriksson is offline Find More Posts by Fredriksson
Wanted AR500 or AR6000 or AR6100 HeliTB Aircraft - General - Radio Equipment (FS/W) 3 Apr 22, 2010 01:41 PM
Found Hobbico Nexstar EP or E-Flite Alpha 450 Sport rc_03 Aircraft - Electric - Airplanes (FS/W) 0 Feb 21, 2010 03:00 PM
Discussion Searching for a new FPV plane - E-flite Alpha 450 opinions phantom4099 FPV Aircraft 12 Nov 13, 2009 03:12 PM
Discussion Anyone know where to find a best price on Spektrum AR6100 or AR6200 or AR500 receiver SSG Scott Hot Online Deals 45 Jul 23, 2009 08:06 PM
Found Spektrum Receiver AR500, AR6100/E v1.6, or AR6200 protus Aircraft - General - Radio Equipment (FS/W) 1 Jun 14, 2009 06:35 PM
