Old Sep 13, 2014, 02:44 PM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
The DPS600 is very popular, and there is plenty of info on conversion.
It is rated at 500 Watts which will manage a bit under 30 Amps when charging a 4S.
Originally Posted by whakahere View Post
Hey guys,
Last week I my PC power supply finally decided to stop working so now it is time to build a new "better" power unit.
I only pull about 30amps Max at a time while charging so making a 1000watt supply is most like over kill. Does anyone know of a good supply that is small and quiet? I have been looking at the DPS 1200FB but here in Germany the cheapest I have found is for 70 euros. Are there others that are recommended?
jj604 is online now Find More Posts by jj604
Old Sep 13, 2014, 03:09 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Thanks, off I go to ebay and see what I can find
whakahere is offline Find More Posts by whakahere
Old Sep 17, 2014, 05:02 AM
Joined Sep 2014
power up HP ML530 570 POWER SUPPLY
Originally Posted by linw View Post
OK, I think I have cracked it.
. . . . . x pwr on
x . x x x . First is short pin enable. Then 3 X gnd - use any of these
Grounding the short pin and the pwr on pins gets the fan roaring like a 747! It also produces blade voltages as follows:-
Blade 1 - chassis gnd
Blade 2 - +3.7V (3.3V)
Blade 3 - +12.82 (12V)
Blades 4,5,6 - gnd
Blade 7,8 - +5.48V (5V)
I still have two concerns. According to a sticker on a supply on a web site (it is not on mine) the Status LED is supposed to be steady green if all is well. Mine is not lit. There is only a green AC pwr LED.
Considering that there is only one blade for 12V, I wonder about its current capacity. There is nothing on the PSU to show what the current capability is and I couldn't find anything by googling. It is a 750W supply so it has to be capable of a lot of current from somewhere!
Anyway, some progress has been made. Next step is to test it with a load. I will report back.
With this pin connection the PSU works very well.... thank you
(Prodromos Athos-Greece)
tsapatis is offline Find More Posts by tsapatis
Old Sep 17, 2014, 06:32 AM
ancora imparo
jj604's Avatar
Joined Jul 2005
Actually, I was a bit cryptic there. The PS rating is higher but the effective charger output is 500Watts.
The DPS600 does 47Amps at 12.15V. That's just over 570 Watts. However charger efficiency of say 90% pulls that down to about 500 watts output from the charger.
Old Sep 27, 2014, 09:03 AM
Joined Sep 2014
is this thread dead? i need some advice with a JD 200 6800 powersupply
150 db is offline Find More Posts by 150 db
Old Today, 06:26 AM
Joined May 2011
dps 900
Hi to all
I need help to operate the Dps 900CB A
thanks
Dan
danmor2 is offline Find More Posts by danmor2
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
