Old Jul 16, 2014, 03:30 PM
Seattle
Joined Sep 2007
4mm connectors are barely suitable for continuous 40 amps. However FMA uses a slightly longer than normal plug that increases contact area. Even still it will tend to run a little warm. You can clean the contacts on the charger and the bananas with some Deoxit. That will help improve the connection and reduce heat.
Gregor99 is online now Find More Posts by Gregor99
Latest blog entry: Dual Powerlab Case Project
Old Yesterday, 06:59 AM
Joined Jul 2014
What sort of output would u get if you use the powerstation with the 8x2?
Get2daChoppa is offline Find More Posts by Get2daChoppa
Old Yesterday, 09:43 AM
BVH
BVH's Avatar
United States, CA, Pismo Beach
Joined Dec 2006
I've got to be missing something simple. I had a couple of Prismatic 3.3V/100 Ah cells that I was discharging for recycling and I wanted to discharge them internally, 1 per channel on my DPL8. I set the discharge current for 20 Amps on each channel and used the 1-5S non-balanced preset with a 2.0 V discharge level. When I use CCS to start the discharge, the screen where the charge/discharge/ etc choice is, I verify that discharge is set for 20 Amps. But when the discharge starts, the best I can get is 10 Amps, 33 Watts and the "set point" reads only 10 Amps., not the 20 I set and CCS confirms. I can't see anything in that preset that would limit the current to 10 Amps. What am I missing?
BVH is online now Find More Posts by BVH
Old Yesterday, 11:13 AM
Seattle
Joined Sep 2007
A general rule of thumb is the charger will be able to deliver about 90% of the supply's power to the packs.
The power station is 1320W which means 1188 watts to the packs. To determine the amount of current, divide 1188 by the pack voltage. For 3s that would max out both channels. For 6s that would be about 23 amps per channel.
Old Yesterday, 11:18 AM
Seattle
Joined Sep 2007
Internal discharge is limited to 10a or 95w, which ever comes first. If you configure the packs as 2s or 3s you will be able to get closer to the maximum internal wattage rating. From the specs:
Output battery discharge current: Internal discharge 10mA to 10A, 95W max Regenerative discharge 10mA to 40A, 1344W max**
Old Yesterday, 11:30 AM
BVH
BVH's Avatar
Joined Dec 2006
Ahhhhhhhh..... Somehow I skimmed right over the 10 Amp max for internal. Thanks!
New Product Introducing the ALL NEW Cellpro PowerLab 6 (EC5 version) Charger Howard Matos FMA Direct 414 Jul 09, 2014 01:15 AM
Discussion New Powerlab 8X2 302 Z28 Batteries and Chargers 9 Jul 27, 2013 08:08 AM
Discussion Revolectrix Cellpro PowerLab 8 (Charges In 5 Min?) Nickerz Batteries and Chargers 1 Feb 11, 2013 02:30 AM
Discussion The NEXT Cellpro PowerLab from FMA/Revolectrix RCnGuy FMA Direct 13 Aug 20, 2012 09:27 PM
Sold Revolectrix/FMA direct Cellpro PowerLab 8 unused new thwang99 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 26, 2010 03:24 PM
