Old Mar 30, 2013, 06:58 PM
Joined Mar 2013
Question
LiPo battery discharge lead came off
Hey guys,
So I crashed my multirotor the other day, and apparently the battery wasn't secure enough because it had fallen off and the positive lead was pulled right out. It's a 4S 4000mah. I've cut open the shrink wrap on the end, and I can see where it was connected but I'm not entirely sure if/how I can put it back on. Everything else appears to be fine. It doesn't look soldered, and I can't imagine it would be safe to put that much heat on a LiPo right?
Thankfully the multirotor is totally fine other than that, and I have another battery. So not a big deal but I'd really like to fix it instead of buying another one.
TigerFire is offline Find More Posts by TigerFire
Old Mar 30, 2013, 08:08 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
It looks like the tab broke off of the cell. It might be possible to repair if you have good soldering skills or if you have access to someone who does. If not then the battery is a write off.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Mar 30, 2013, 09:43 PM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Probably a gonner. By the time you figure out you can't get the solder to stick to the remaining tab you will have put so much heat into the tab that the seal will be voilated.
Rick
rampman is offline Find More Posts by rampman
Old Mar 30, 2013, 10:12 PM
Joined Mar 2013
Well, good thing I haven't tried it yet. Is there anything I can do? I'd really prefer not to buy a new battery.
Old Mar 30, 2013, 11:19 PM
Joined Mar 2013
I managed to fix it! I figured it was worth a try. I was able to sort of crimp the the two pieces together to get good contact, and then I soldered it very carefully.The solder bond isn't great but it works and I put a ton of strong tape over it. I'll be extra careful with it until I can get a new one. Thanks for the info though guys.
Old Jul 21, 2014, 11:23 AM
bosco99's Avatar
United States, CA, San Clemente
Joined Apr 2014
Thanks so much for this posting. First had the lead come off then the lead tape and I had no idea what to do as batteries are not inexpensive. Got it on and battery checker says all okay. thanks again for the added confidence to pursue this repair
bosco99 is offline Find More Posts by bosco99
Old Jul 21, 2014, 12:29 PM
United States, WA, Woodinville
Joined May 2014
They are usually soldered to the leads, and tabs are spot welded to other tabs.
Put some epoxy over the joint, that will keep it together.
James_S is offline Find More Posts by James_S
Old Jul 21, 2014, 03:09 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
If the repaired battery causes a crash it could cost a lot more to repaire than another battery would have.
I use to read post of people useing epoxy,shoe goop ,JB Weld etc to repaire holes / cuts in LiPolys and some clamping bent ones in a vice to stregthened them out. All seem very risky to me and a decent 3S 1500 does not cost $40 or more like they did 10 years ago.
FYI I have the special flux and solder to solder to LiPoly tabs which do not have the nickle taps spot welded to them burt these days LiPolys are not worth the effort to repaire unless they are very expensive ones and you have enough bad (damaged) ones on hand to salvage cells from.
Old Jul 21, 2014, 05:41 PM
Georgia
Joined Jun 2007
I'd be concerned that the repaired connection would not be capable of withstanding 10C or 20C current.
chuck75 is offline Find More Posts by chuck75
Old Jul 21, 2014, 11:12 PM
Joined May 2014
Try it out on the ground and find out. I see no reason why it wouldn't though, people solder connectors on batteries all the time. I wouldn't consider patching up a torn pouch but I see no issue with repairing a wire that got torn off. As long as the cell itself hasn't been crushed or the seal compromised it should be fine. If the seal is bad, the cell will likely start to puff after a few days and then you know it's toast.
Old Jul 22, 2014, 10:04 AM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I lost a plane from a simular damaged tab as the OP has. That is why I stated it is probably a gonner.
My pack was a 5S 5000. I "thought" I had enough solder on it to hold the main lead to the tab. I did...until I did a vertical climbout and the high continuous amps caused the repair to get hot and fail. Granted, I knew it was marginal but it was the best I could do with the little piece of tab left.
Rick
Sold Eflite UMX lipo battery lead for lipo chargers Jorge Halstead Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 05, 2013 10:14 PM
Discussion Correctly discharging a Lipo battery pyrohaz Batteries and Chargers 7 Jan 29, 2013 01:07 AM
Discussion Lipo battery discharge rating(S) ham4864 Multirotor Electronics 3 Jan 12, 2013 07:33 PM
motor lead came off isaacslaw Castle Creations 1 Sep 22, 2004 09:22 PM
GWS 300C Negative lead came off?? BrunswickOH Power Systems 12 Oct 20, 2003 11:48 PM
