Old Oct 31, 2006, 08:22 AM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
AC World Kit wind for EDF-64?
I have some kits waiting for the GWS-262
Any suggestions on what wind to start with?
rdeis is offline Find More Posts by rdeis
Old Oct 31, 2006, 10:31 AM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
rdeis,
What bat. are you planning on using? I"ve got two of these in edf55's in my mig 25 (5 turn NSNSNSNS wye) 16-17 amps each so this setup needs a 20c 2100 min. I think the NNSSNNSS setup may be better but I've only tested it in the E-flight 68mm fan which prob. pulls a few more amps then the edf64. The E-flight fan pulled around 19-20 amps (7 turn wye) so prob. 7-8 turn in the edf64. All my bats. are 3 cells.
I just got three more of these also, so I hope to mount one soon into a 64 for comp.
Here is a link to a bad video of the Mig using AC motors in edf55's.
http://www.rcgroups.com/forums/showthread.php?t=527899
Cheers--Stacker
stacker is offline Find More Posts by stacker
Old Oct 31, 2006, 11:12 AM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
Planning on 3 cells, hadn't decided the capacity yet. I'll have to see what the thrust and amps comparisons dictate, but I was hoping to keep somewhere close to 30A because there are lots of batteries available that will pump out 30A. I eagerly await your test results. (-:
The prototype in the video was running at about 26A full throttle and performed very nicely, but I'm at high altitude and will be a little heavier.
With 7-8 turns are you suggesting multiple strands, or heavy gauge wire?
Old Oct 31, 2006, 11:44 AM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
rdeis,
I've been using 26ga. multi strand. If you want to keep it at 30 amps you will prob. have to go with 8 turns for the NNSSNNSS setup and you might be able to fit three strands of 26ga. but I did three on my seven turn and it looked pritty full. Might also try two strands of 24ga.
On my mig setup using a TP2100 prolight both motors caused the bat. to sag just under 30 amps, I also puffed the prolight doing it. I've switched it to a 20c pack now, but the weight sucks. I think the new TP extreme packs would be nice with a twin like the 262.
You may be at a even higher altitude then me (4500) in S.L.C. and that does make it hard. I'm sure the gws video was shot at a little above sea level.
Cheers--Stacker
Old Oct 31, 2006, 12:07 PM
darmar is online now
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
Multiple strands are easyer to wind.
Just tested this kit in edf 55, cut rotor to 3 blades.
4 strands 30 ga wire, 7 turns,Y, NSNS magnets (4 only).
On 3s 2250 15c battery.
415 grams of thrust at first minute, 18A. After that 380 grams 15A. Could not measure the voltage under load.
Rotor is pain to balance if possible at all.
I will try 6 strands, 6 turns,Y of 30 ga wire and NSNS magnets.
GWS fans have nice but agressive aerodinamic blade design.
We might all switch to XF fan, simple efective design and quiet as reported by rcwincent.
darmar is online now Find More Posts by darmar
Old Oct 31, 2006, 12:37 PM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
We're closer to 6500. I'm going to make the nacelles easy to disassemble so I can experiment with the motors.
Old Oct 31, 2006, 12:52 PM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
I think they need to build a model port in Death Valley since it is below sea level. Also be a nice place for us high altitude guys to go in the winter. Just have to leave before summer or all the foam would melt.
Cheers--Stacker
Question Cheap brushless upgrade for GWS EDF-64 Bad Driver Electric Ducted Fan Jet Talk 9 Mar 28, 2005 01:34 AM
New AC World diy brushless kit mudlark Power Systems 2 Sep 09, 2004 05:51 AM
Good wind for Aircraft World "Almost Built" Brushless Motor goofeyfoot Power Systems 1 Jul 12, 2004 06:57 AM
BL for GWS EDF 64 Bill Bergman Electric Ducted Fan Jet Talk 15 Jan 03, 2004 05:23 PM
Need Nacell and POD kit for EDF-75... Captain Carlton Electric Ducted Fan Jet Talk 2 Aug 09, 2003 03:26 AM
