Old Apr 25, 2015, 10:39 PM
BSquared18 is offline
Find More Posts by BSquared18
BSquared18's Avatar
Joined Jun 2012
Question
Airfoils in Phoenix 5
How does one decide which wing airfoil to use when building a particular model? Is there a description anywhere of the characteristics of each airfoil?
I recall reading somewhere in these forums that for many models an airfoil with a curved upper surface and flat bottom works well. As far as I can tell, none of the airfoils in Phoenix Builder meet that description. Some come closer than others, but none that I could see that are completely flat on the bottom. Any thoughts about that?
Bill
BSquared18 is offline Find More Posts by BSquared18
Old Apr 26, 2015, 02:35 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
The idea is that you decide what you want (or are using) on the actual model then choose something close to it in the Builder. It isn't really intended to teach you how to design models.
The airfoil for the real thing is chosen depending on how you want it to fly and how you intend to build it. Trainer and slow fly types often use a cambered airfoil with a fairly flat base, sport and aerobatic models are more likely to use a zero-camber airfoil (often called symmetrical, curved the same top and bottom). And there are many other shapes possible for a whole range of purposes.
Steve
slipstick is offline Find More Posts by slipstick
Old Apr 26, 2015, 08:54 AM
BSquared18's Avatar
Joined Jun 2012
Thanks.
Bill
Discussion Need to make a clark-y airfoil in DTF compressor man Foamies (Scratchbuilt) 14 Jan 17, 2015 07:46 AM
Discussion Setting up SAFE in Phoenix 5 jobinseattle Simulators 3 Dec 29, 2014 11:38 AM
Discussion V977 in phoenix 5 Pedro Marques Simulators 0 Nov 17, 2014 03:27 PM
Discussion Chinook in Phoenix 5 Flight Sim helimental Beginner Training Area (Heli-Electric) 5 Sep 08, 2014 09:44 AM
Discussion Need help in buying Phoenix R/C 5 seanndamien Simulators 4 Mar 19, 2014 07:01 PM
