Old Apr 04, 2015, 12:24 PM
Gary Cee is offline
Find More Posts by Gary Cee
No spark needed
Gary Cee's Avatar
Joined Apr 2010
OS Gemini Cam Bearings
I have had to repair 3 different OS Gemini twins in the last few weeks . When stripping them down it was obvious that all of them had quite a bit of clearance in the cam bearing assemblies . A couple of them were at .010 " clearance per side .
All of the engines were rather low time engines and it seemed that the bearings were very prematurely worn .
Has anyone else seen similar results ?
Gary Cee is offline Find More Posts by Gary Cee
Old Apr 04, 2015, 06:39 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
This is interesting. I will be doing bearings in my FT-160 before flying this season so I'll have a look. How did these engines look inside otherwise?
Greg
gkamysz is offline Find More Posts by gkamysz
Old Apr 04, 2015, 06:55 PM
Gary Cee is offline
No spark needed
Gary Cee's Avatar
Joined Apr 2010
Thank you Greg , I was hoping to hear from you .
One of the engines had lost a con-rod but looked great otherwise the other two were crash damage but the innards aside from cam bearings were very nice on the inside . Two were synthetic oiled , one had some castor residue but no real rust issues .
They all had similar cam bearing clearances on both ends of the camshaft . By measuring over the bearing bore with the OD I saw about .24 MM clearance per side ! Just a rough measure but still a lot of slop !
Please let me know what you see in your engine ,
Sold OS Max Gemini FT-160 Twin New Mint In Box $650.00 FREE SHIPPED!!! stevster Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 14, 2015 08:46 PM
Sold OS Max Super Gemini FT-300 Twin New Mint In Box $875.00 FREE SHIPPED!!! stevster Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 10, 2015 12:27 AM
For Sale Saito FA-30S Crankcase w' bearings Rear Cover & Cam Cover gamma13r Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 31, 2014 02:58 PM
Sold Magnum 91 XL RFS low usage with fresh Boca double shielded bearings and cam bearings! Corsair416 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 28, 2014 04:55 PM
Sold OS FT-120 Gemini (Not GemInI II) rcb7761 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 27, 2013 06:43 AM
