Old Oct 30, 2014, 03:11 PM
Feigo is offline
Find More Posts by Feigo
Joined Apr 2011
New Product
HobbyKing - Turnigy TGY-i6 AFHDS Transmitter and 6CH Receiver
The Turnigy TGY-i6 is a great entry level 6-channel telemetry 2.4ghz computer transmitter that uses solid and reliable Automatic Frequency Hopping Digital System (AFHDS) spread spectrum technology. The Turnigy TGY-i6 has both a nice quality look and feel, while the programming is simple to use. The TGY-i6 also has an impressive list of features and includes a TGY-iA6 6-channel receiver. Suitable for both model Heli and Airplane, the Turnigy TGY-i6 is a superb budget computer radio for both new pilots and experienced pilots alike!
The ultra slim case design ergonomically fits your hands leading to less hand fatigue especially during long flights. Digital trims, backlit LCD screen, and simple programming give the TGY-i6 a modern feel with all the features you want. With a low profile antenna, the TGY-i6 is easy to store and no worries about breaking it. Adjustable length sticks, and a loop for attaching a neck strap round out the list of comfort features this radio offers. For changing flight modes or multiple flap position options, the TGY-i6 has a 3-position switch, as well as two adjustable knobs.
Expand the capabilities of your models or just know what is going on with the optional telemetry receivers and variety of sensors. Normally you would have to spend hundreds of dollars to get a transmitter with this capability. Not so with the availability of the TGY-i6.
For the price, the features the TGY-i6 offers make this one of the best radios available dollar for dollar.
Features:
• Entry level 6 channel 2.4ghz radio with telemetry capability
• Dual Rate/Trims/Gear/Flap/Gyro Gain Adjust/Flight Mode/Throttle Hold/Hover Pitch Switches
• Easy to use Programming & Navigation Buttons
• Supports Heli/Standard Wing/Elevon/V-Tail
• 20 Model Memory
• 8 Character Model Name
• Trainer and charging ports
• Backlit LCD Screen displays real time transmitter and receiver voltage
• 4 Stick Mode Selectable
• Optional telemetry receivers and sensors available separately
http://www.hobbyking.com/hobbyking/s...r_Mode_2_.html
Feigo is offline Find More Posts by Feigo
Old Oct 30, 2014, 03:39 PM
jdlalonde is online now
Find More Posts by jdlalonde
Joined Feb 2012
I will get one of these. I hear it will work with the previous FLYSKY receivers. I love my FS-TH9X, but the FS-TX9X is overkill for some of my 2 servo planes. I might have to try telemetry!
jdlalonde is online now Find More Posts by jdlalonde
Old Oct 30, 2014, 03:52 PM
Joined Feb 2012
I don't think it has a timer! Darn it.
Old Oct 30, 2014, 06:42 PM
crazy8s is offline
Find More Posts by crazy8s
crazy8s's Avatar
Pennsylvania, USA
Joined Sep 2008
What makes you think that? Under the Basic Functions list for the radio in the link above it says 'Timer".
crazy8s is offline Find More Posts by crazy8s
Old Oct 31, 2014, 06:33 AM
Harri Pihl is offline
Find More Posts by Harri Pihl
Suomi, Länsi-Suomi, Uurainen
Joined Jan 2004
I've got one of these, few comments:
- it's small, thin and light, much smaller the 9x.
- software is very basic, can't find the timer.
- sticks are small and short though feel ok.
- channels 5 and 6 can be assigned to the switches or pot or mixed with other channels.
- there is actually two tx aerials, one sticks on the plastic antenna cover and the other is at 90deg angle inside the handle.
- overall a bit toyish due to size but still rather solid feel when you keep it in hand.
- telemetry shows rx voltage and error rate as percentage (0% means no errors)
Harri Pihl is offline Find More Posts by Harri Pihl
Old Oct 31, 2014, 11:12 AM
prefabu is offline
Find More Posts by prefabu
Kansas City
Joined Dec 2009
So how many different incompatible protocols are used by radios marketed as Turnigy or OrangeRx??
prefabu is offline Find More Posts by prefabu
Old Nov 07, 2014, 11:06 AM
SpeedsterDEN is offline
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
And it got 3 free mix.
Just got one of theese.
Now I have mixed in 4 planes, and it was pretty easy.
Hope to fly with it soon.
Cheers
Soren
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Nov 07, 2014, 02:34 PM
Joined Feb 2012
Cheers
Soren
Did you figure out the timer?
Old Nov 08, 2014, 02:45 AM
Joined May 2010
There is no timer.
Old Nov 09, 2014, 12:00 AM
Joined Jan 2004
Tested it yestarday in a indoor event with 8 other 2,4GHz systems on air same time (combat), no problems so far.
Old Nov 28, 2014, 06:13 PM
Dessa is offline
Find More Posts by Dessa
Joined Dec 2012
Hi - could you briefly explain how you set up your 4 models - do you need to set up model name/number/type in Tx before you bind the relevant Rx?
Dessa is offline Find More Posts by Dessa
Old Nov 29, 2014, 03:42 AM
Joined May 2010
I dont think so, but maybe it is like that.
but why not do that first.
You have to do it anyway
So start with that.
and remember to hold cancel Down to store the Things you do.
Then pick the wrench and screewdriver meny and set the Things you whant there. and remember to press the cancel to store after any change.
To bind, put the bind plug in bind/batt and the batt in any other slot and then it shoud blink.
Press the bind range test on the rx and switch on the rx.
Then the blink will stop and go to steady lights.
take out the binding plug and you are ready
Good luck
Soren
Old Nov 30, 2014, 05:20 AM
Dessa is offline
Joined Dec 2012
Thanks Soren - I am currently waiting on an Rx for my second plane and look forward to trying what you have suggested.
Thanks for taking the time to reply.
Derek
Australia
Old Nov 30, 2014, 05:57 AM
Joined May 2010
Derek
Australia
Just take out the rx on your first plane and bind it Again to your second plane in the tx , and set it up as you like.
You dont need a rx for all your planes.
S
Old Dec 21, 2014, 01:50 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
i find it pretty nice little radio,
love it, even if its not very pro radio
does it has fail safe?
for telemetry i read it needs the 10 ch receiver, with the 6ch receiver still shows Voltaje of battery?
wallaguest1 is offline Find More Posts by wallaguest1
Sold Turnigy GTX3 AFHDS 2.4ghz 3 Channel Radio System for RC Cars - Includes Receiver Dalrock69 Cars - Accessories (FS/W) 2 Jul 31, 2014 11:07 AM
Sold FLYSKY RC FS-T6 2.4G AFHDS 6 ch Transmitter Receiver set ericsch333 Aircraft - General - Radio Equipment (FS/W) 1 Sep 11, 2013 10:34 PM
Sold Turnigy TGY 9X Transmitter with 9X8Cv2 8 channel receiver JKN Aircraft - General - Radio Equipment (FS/W) 1 Feb 18, 2012 10:36 AM
Sold HobbyKing HK-T6A V2 6CH Transmitter/Receiver MrDusanmandic Aircraft - General - Radio Equipment (FS/W) 1 Oct 13, 2011 09:12 AM
Sold HobbyKing HK-T6A V2 6CH Transmitter/Receiver MrDusanmandic Aircraft - Electric - Multirotor (FS/W) 1 Oct 13, 2011 09:10 AM
