Old Feb 01, 2011, 04:10 PM
atjurhs is offline
Find More Posts by atjurhs
agony sweetns the victory
atjurhs's Avatar
Any Flying Field Across America
Joined Jul 2005
Question
Airfoil Percent Thickness Computation
Hey guys,
A simple question that I think I know the answer to, but would like to verify:
How is an airfoils' percent thickness computed?
In the attached JPG, does the "simplified airfoil" have a 5% (max Y-value) or a 2.5% (average Y-value) or some other value percent thickness?
Thanks, Todd
atjurhs is offline Find More Posts by atjurhs
Old Feb 01, 2011, 04:22 PM
dephela is offline
Find More Posts by dephela
the flying is good
dephela's Avatar
USA, CT, Hamden
Joined Oct 2002
I don't have any facts to back my estimate but I'd say 5%.
dephela is offline Find More Posts by dephela
Old Feb 01, 2011, 05:32 PM
nuevo is offline
Find More Posts by nuevo
nuevo's Avatar
United States, AL, Madison
Joined May 2002
Airfoil programs display maximum % thickness. 5% in your example.
nuevo is offline Find More Posts by nuevo
Old Feb 01, 2011, 06:33 PM
atjurhs is offline
atjurhs's Avatar
Joined Jul 2005
Thanks nuevo! Right now I don't have an airfoil program that's easy to use, but as time permits I'm working on learning XFLR5....
So for an airfoil with a curved top surface AND a curved bottom surface (as most airfoils are), do airfoil programs still use the max value on the Y-axis or does it also subtract off the bottom surface giving a relative distance between the two or do they perform some other (presumably calculus based) algorithm?
Old Feb 01, 2011, 07:58 PM
AMBeck is offline
Find More Posts by AMBeck
AMBeck's Avatar
Charleston, SC
Joined Nov 2007
It's the max value between the top and bottom surface. So, if you have a 10" chord and 0.85" maximum distance between the top and bottom surface, you have an 8.5% airfoil. It can be symmetrical, flat bottom or under cambered, all are 8.5%.
AMBeck is offline Find More Posts by AMBeck
Old Feb 01, 2011, 08:25 PM
atjurhs is offline
atjurhs's Avatar
Joined Jul 2005
ok great, thanks for the explanation!
Old Feb 02, 2011, 07:03 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Todd,
Here's a great online book that's free to read:
http://www.desktop.aero/appliedaero/...lgeometry.html
Also here is a great book too on polars:
http://www.b2streamlines.com/books/booktitles.html
Curtis
Montana
Curtis Suter is online now Find More Posts by Curtis Suter
Old Feb 02, 2011, 10:29 AM
atjurhs is offline
atjurhs's Avatar
Joined Jul 2005
Thanks for the links Curtis!
In the past I counted on Profili2 to do all the work for me of designing airfoils. I no longer have a PC, but have found the light and switched over to a Mac There is XFLR5 for a Mac (it's a Unix based OS). I just haven't learned to use XFLR5 yet, but I will....
Old Feb 02, 2011, 11:07 AM
AMBeck is offline
AMBeck's Avatar
Charleston, SC
Joined Nov 2007
Todd, XFLR5 is a 1 stop shop for analysis. It's a little unfriendly at first, but well worth the effort to learn. Go for it!
Old Feb 02, 2011, 11:40 AM
nuevo is offline
nuevo's Avatar
Joined May 2002
I didn't have time before. Below is an image showing a sample airfoil I generated. The chart at the bottom displays the thickness of the airfoil (10%), and the point where that max thickness occurs (30% chord). I drew a yellow line showing approximately where the max thickness occurs. Hoping this picture will clear up any questions you had.
Old Feb 03, 2011, 09:27 AM
atjurhs is offline
atjurhs's Avatar
Joined Jul 2005
Yep, nuevo, thanks!
My next step is to determine what percent thicknesses will be needed to maintain a constant "rise" value on the Y-axis as the X-axis grows.
This "airfoil" (well actually an obtuse shaped triangle, not the shown right triangle) will be used as a flap on a wing that has a constant TE thickness. A bit of math and I should have it ready to send off to Laszlo at Compufoam......
Old Feb 09, 2011, 06:16 AM
marc.pujol is offline
Find More Posts by marc.pujol
Marc PUJOL
Joined Feb 2010
Which version of XFLR5 are you using.
My version do not provide such mistake you found.
The last one is 6.02 and the 6.03 is n the way...
I strongly recommand everybody to look at XFLR5 website regularly to get updating.
Marc
marc.pujol is offline Find More Posts by marc.pujol
Discussion Thickness of airfoil and Efficiency? GreenAce92 Sailplane Talk 22 Mar 07, 2009 12:51 PM
Zero lift AOA changeing with airfoil thickness. DennisRB Slope 11 Jul 19, 2005 04:45 AM
Why do airfoils curve slightly past the peak thickness of the airfoil towards the TE? BytheBookie3 Modeling Science 3 Jun 22, 2004 12:48 PM
AIRFOIL HELPPPPP! (thickness/ section) crashbuilder Slope 21 May 03, 2004 10:45 AM
How does changing thickness effect airfoil characteristics? Joel K. Scholz Modeling Science 3 Jul 02, 2003 07:51 PM
