Old Apr 20, 2009, 06:11 AM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
Build Log
Homebuild
Hi all,
Im building a profile Autogyro and was interested in any helpfull tips you all might have. It is only a small model as shown in the pictures.
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Apr 20, 2009, 06:46 AM
SafeLandings is online now
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Doug,
Just keep it as light as you possibly can, try not over engineer things.......and make a bigger horizontal stab
Regards Rich
SafeLandings is online now Find More Posts by SafeLandings
Old Apr 20, 2009, 10:34 AM
Joined Jul 2008
Rich,
Current estimated mass is 500g (17.7oz) completed but Im still thinking on rotor(s) length. Will have a second look at the horizontal stabilizer.
Doug
Old Apr 20, 2009, 10:44 AM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Doug,
around 17", I suppose.
Jochen
JochenK is offline Find More Posts by JochenK
Old Apr 20, 2009, 01:38 PM
Norfolk Flyer is offline
Find More Posts by Norfolk Flyer
Suck it and see
Norfolk Flyer's Avatar
Cromer, North Norfolk Coast, UK
Joined Aug 2008
Hi Doug,
Can you give fuselage length as shown in pic. to get things into proportion.
Please keep the thread posted as to progress. Always good to see an original idea.
Good luck.
John
Norfolk Flyer is offline Find More Posts by Norfolk Flyer
Old Apr 20, 2009, 06:52 PM
Joined Jul 2008
Jochen and John,
I have some at 16" already but can make some new ones. The total length of the fuselage is only 500mm (19.6") including rudder. Everything is made overestimated so I can go back and fine tune later.
Is it ok to make the top part of te DC unit out of balsa or should I mechine one out of aluminium with a spindle turned onto it?
Doug
Old Apr 20, 2009, 07:18 PM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Doug,
before you build nything new, try the 16" ones first.
No need for aluminium, but I wouldn't use balsa either. Have a look at the head I'm using for my 520 g Minimum:
http://www.rcgroups.com/forums/attac...mentid=1471302
Jochen
Old Apr 20, 2009, 10:12 PM
Joined Jul 2008
Jochen,
I couldnt replica your exact design shown due to lack of meterials but I have come up with something that should work fine.
Now I have to make the gearbox for it.
Old Apr 21, 2009, 01:18 AM
Joined Jul 2008
Update
Hi all,
Just some more pics of what Im up to. Neally ready for ground taxi and spin up tests.
Total mass is at 534g (18.8oz) with three 1" 1/2' aerobalsa blades at 16". Can someone help me with disk loading as Im a novice with rotorcraft equations?
I calculated it at 6.52 pounds per square foot(?). Please correct me.
Rich, no I havent changed the horizontal stab yet but Im onto it.
Doug
Old Apr 21, 2009, 01:41 AM
Hephaistos is offline
Find More Posts by Hephaistos
Tannenzšpfle-Terminator
Hephaistos's Avatar
Baden-Baden, Germany
Joined Dec 2008
Hello Doug..........
Disc loading is calculated this:
mass-of-autogyro / rotor-disc-area
or:
mass-of-autogyro / (rotor-radius)≤ / PI
The disc-loading shall be in the region of 2 or 3 ounces per square-foot. The horizontal-stab-area shall be 4 % to 8 % of the rotor-disc-area, the vertical-stab-area about the half of the horizontal. Thats only a very rough idea, but as you have got big vertical and horizontal areas in front of the centre of gravity, you might need big stabs on the tail to compensate.
Can you adjust the downthrust of your motor easily? This will become important for the first tests...
I hope this helps a little...........
Bye
Hephaistos is offline Find More Posts by Hephaistos
Last edited by Hephaistos; Apr 21, 2009 at 02:56 AM. Reason: corrected a bloody mistake
Old Apr 21, 2009, 02:20 AM
Joined Jul 2008
Mike,
Thanks for the info. Just having a spot of trouble. When I use your formula;
rotor-disc-area / mass-of-autogyro
(PI(16/12)^2) / 18.8 = 0.2970 oz per ft^2
and
rotor-diameter * PI / mass-of-autogyro
((32/12)*PI) / 18.8 = 0.4456 oz per ft^2
Is this me doing something wrong or are these the correct answer(s) (there are 2 different answers, what did I do?)?
Yes I can adjust the downthrust easily, and I will do calcs for the % stabilizer surface's area's I have.
Doug
Old Apr 21, 2009, 02:44 AM
Hephaistos's Avatar
Joined Dec 2008
Hello Doug...........
It was seven in the morning when I wrote the formulas........
I edited my previous post to have the correct formula, I am sorry for the mishap. The other values are checked, no mishap there. Perhaps my old-style steam-driven thinking-machine wasnīt heated up to working temperature this early in the morning.........
Bye
Old Apr 21, 2009, 03:00 AM
Joined Jul 2008
Mike,
Cheers, worked it out now at 3.37 oz per ft^2.
Thanks again
Doug
Old Apr 21, 2009, 03:18 AM
Hephaistos's Avatar
Joined Dec 2008
Hello Doug.............
Same result as me. 3,37 ounces per square-foot seems to be okay for a first try.
Doug, where are you living? The distance stated on the forum makes me think that its really late at night at your place....
Bye
Old Apr 21, 2009, 03:29 AM
Joined Jul 2008
Mike,
Im in Western Australia, right down on the south coast 120km from Albany. Currently it is about 4:30 pm so about an hour before sunset. We are currently in a thunderstorm so no model flying today, only building for me.
Doug
