Old Sep 08, 2008, 11:04 PM
ForceFedDSM's Avatar
Massachusetts
Joined Jun 2008
Can I use a AR6200 without the second receiver/antenna?
I have a spektrum AR6200 that came with my dx6i. I was wondering if I could use it without the piggyback receiver/antenna on my EXI450?
Jared
ForceFedDSM is offline Find More Posts by ForceFedDSM
Old Sep 08, 2008, 11:14 PM
JustinMoore12's Avatar
USA, VA, Woodbridge
Joined Sep 2007
Yup just figure out a place to mount it. Alot of people mount it on the tail servo, there are alot of options though.
JustinMoore12 is offline Find More Posts by JustinMoore12
Old Sep 08, 2008, 11:34 PM
Christchurch, New Zealand
Joined Jun 2006
Don't remove the satellite, even though the RX will work without it.
Why? A 450 heli is dangerous, and the satellite makes the link far more reliable. The weight is negligible.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Sep 09, 2008, 05:42 AM
LaurenceGough's Avatar
Reading, UK
Joined Sep 2007
There's no need to use it if you can't find a good space. I used to run a AR7000 on my 450 but I now have been running a 6100e, same IMO but lighter.
Then again the 6200 is lighter than the 7000.
LaurenceGough is offline Find More Posts by LaurenceGough
Discussion Can you use the AR7000 RX without the second RX? dacaur Radios 2 Mar 07, 2007 09:51 PM
Help! Can I use 2 Cell Li Po with receiver? John Kim DIY Electronics 3 Feb 24, 2006 12:42 PM
Broken receiver antenna - can I solder it? seftonde Electric Plane Talk 10 Jul 13, 2004 06:22 AM
can i use a bullet connector between my antenna and my receiver? asjeep Radios 1 Jul 10, 2004 10:28 PM
I broke my hitec antenna (can I use a different brand) thor4944 Radios 1 Dec 09, 2003 02:43 AM
