Old Sep 04, 2002, 08:54 PM
TeddyTyler is offline
Find More Posts by TeddyTyler
Ronplanes
NY, LONG Island
Joined Jan 2001
40 degrees
Control throws:
Approx 40 degrees both ways for all surfaces. ====================== What is this in inches 3/16 1/4 or is this from a full 360 or 90 degree , thanks if you can help me out on this sorta scratch built by someone and Im now buildind it.
TeddyTyler is offline Find More Posts by TeddyTyler
Old Sep 04, 2002, 09:07 PM
Andy W is offline
Find More Posts by Andy W
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
It means 40 degrees up and 40 degrees down from neutral (seems rather extreme for a model of this type).
If the surface is 1/2" long, the 40 degrees is about 1/2" from neutral.
Old Sep 04, 2002, 09:37 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
40 degrees is WAY too much surface motion unless you intend to fly the airplane slowly and in a hover.
I doubt that is your intention, from the picture.
It will not fly well or very long.
Try 20 degrees.
Sparky Paul
http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff
http://home.earthlink.net/~pjburke1/aindex.html
Sparky Paul is offline Find More Posts by Sparky Paul
Old Sep 04, 2002, 11:15 PM
KillerWatt is offline
Find More Posts by KillerWatt
Colonial Heights, Virginia, USA
Joined Mar 2001
hi Teddy...... 40 deg is about 1/2 way between straight up vertical & horizontal flat .................. kw
KillerWatt is offline Find More Posts by KillerWatt
Old Sep 05, 2002, 04:05 AM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
Hi Teddy,
That plane is my design, the Coros 400. I used 40 degrees and I quite liked it, but if you don't want that sort of throw then try it around the 25/30 degree mark.
40 degrees is about 12mm, if I recall the aileron width (6 flutes?) correctly.
The reason I used 40 degrees is I propped it for fun, not speed, with a 6*3 folder. At higher speeds (using a prop like a 4.7*4.7 or something) I'd imagine you'd use a lot less throw.
Great to see my design is getting around
Trizza is offline Find More Posts by Trizza
