Old May 11, 2015, 11:34 AM
fasteddie123 is offline
Find More Posts by fasteddie123
FastEddie123
United States, MN, Lake Elmo
Joined Nov 2013
Originally Posted by JimNM View Post
8k is sufficient.
Thanks --eddie
fasteddie123 is offline Find More Posts by fasteddie123
Old May 11, 2015, 12:16 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
14 (poles) * 1120 * 11.1 (V) / 20 (word of mouth constant) = 8702 Hz.
So better 8kHz.
Middle of the road between 8 and 16 is at about 1200kv and 4s, or higher RPM.
renatoa is offline Find More Posts by renatoa
Old May 11, 2015, 12:31 PM
FastEddie123
Joined Nov 2013
So better 8kHz.
It runs so smooth I though maybe it wasn't reving.. its at 8khz .. good to know..
need good weather now.. Salangane 2.2 m maiden -- e
Old May 18, 2015, 09:25 AM
FastEddie123
Joined Nov 2013
1120 kv 820watt glider drive is perfect in this application. 12x10 prop, 3s 65c 1800 lipo, 70 amp esc.. Salangane 2.2m F3F .. (w zero additional weight setup arranged for proper CG) )
straight up vertical and disappears in about 20 second., turbo spinner and spoon cooling vent - motor didn't get over 120 degrees F on a 75 degree day - not continuous motor runs ) . - eddie
ps it's 65 oz full up.
Old May 18, 2015, 09:30 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Good to know it works for ya'. I have my motor on an 60 amp esc, 4s 2700 and a 14x8 prop. It hauls the Mystique RES to ALES heights as far down range as I like it in ~20 seconds. It is super nice to not have to worry about rotating can eating your motor leads.
I think these motors are a great value @ less than $40.00.
JimNM is offline Find More Posts by JimNM
Old May 18, 2015, 06:47 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Good to know. I picked up the 840 kV version for an F5B Soitare that is waiting in the racks for me to build it out. They tell me these birds were typically fit out with 2KW motors on 27 cells so they were powerful but heavy. Go to these brushless and lipos and they can be so much lighter and powerful on half the watts.
aeajr is offline Find More Posts by aeajr
Old Jul 04, 2015, 11:14 AM
wingloada is online now
Find More Posts by wingloada
wingloada's Avatar
United States, MD, Lutherville-Timonium
Joined Apr 2012
Prop choice
I've read the thread and thanks to everyone who has contributed. I have two prop choice questions.
1) I'm building an eSupra 3.4M ALES plane and I plan to use the Gliderdrive 4.6 840kv in it. The plane will be about 65-67 oz AUW. For ALES flying, is there a suggested starting prop diameter/pitch? I have a watt meter but I don't have a stock of props at this range to test and so I'm looking for a good starting prop/battery choice for both a 3S and 4S system. I have a 60A YEP ESC.
2) I've built a custom full-house built-up wing 126" ALES plane that weighs about 62 oz AUW with the same motor and ESC. I used "Drive Calculator" software to select a prop but from what is written here, I may be under propping the motor and getting less power than is possible. The plane has not flown yet and I'm looking for a good starting prop/battery choice for both a 3S and 4S system for it as well. There's not a lot of room for battery. A nanotech 1300 3S fits and there's room for a 4S with similar length dimensions.
I know there will be multiple opinions but they will all be helpful.
Thanks to all in advance.
W
wingloada is online now Find More Posts by wingloada
Old Jul 04, 2015, 11:53 AM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
14x8 works 3s and 4s for limited run with cooling.
Eflight stock prop for Mystique FTW!
Old Jul 04, 2015, 02:30 PM
renatoa is offline
Joined Sep 2007
+1 for 14x8 and 3s, is what I am using in my Graphite 3.1 1900 grams
Old Jul 05, 2015, 01:14 PM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Wingloda
with a 12x8 Aeronaut cam carbon prop and a 4-s 850 mAh 45-90 C nano battery on that set up you should get around 95 oz of thrust. That was the numbers I came up with for My setup and that puts me at a weight to power ratio of 1.32 to 1 for a 72 oz plane.
Clarence
onethermal is offline Find More Posts by onethermal
Old Jul 05, 2015, 02:37 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
W
I have not read your entire build thread but I see you are making your own pod. That is good as most Supra fuselages could not take a motor this wide.
Mini-Review New Turnigy Sk3 Series Outrunners, Turnigy's "High end" Outrunner daign Multirotor Talk 22 Sep 12, 2014 04:42 AM
Discussion Turnigy Aerodrive SK3 OR NTM Prop Drive Series OR easy match series sebbe Power Systems 10 Dec 23, 2012 02:33 PM
Discussion Turnigy D or SK3 series? jtaylor996 Power Systems 2 Nov 29, 2012 09:25 PM
For Sale Turnigy Helidrive SK3 Competition Series 4 NIB blawren Aircraft - Electric - Helis (FS/W) 0 Nov 21, 2012 10:51 AM
For Sale Turnigy G60 and Turnigy SK3 4250 fnlrun Aircraft - Electric - Power Systems (FS/W) 3 May 21, 2012 12:20 PM
