Old Mar 23, 2015, 04:06 AM
Rangarid is offline
Find More Posts by Rangarid
Joined Aug 2010
Low Budget DIY Arduino Frsky GPS
Hi,
i made a small project, where you can interface any GPS you like with an arduino. The arduino will create telemetry data to feed your frsky telemetry receivers.
It currently only works with Frsky D-Series RXs, but i'm already working on the SPort implementation to use with X-Series as well.
It works with D-Series and X-Series receivers.
The setup is pretty easy and no additional hardware is needed, as all the magic happens in the arduino. Normally you need to invert the serial logic level for frsky receivers. This is already done in the SoftwareSerial implementation.
You only need 3 wires: 5V, GND, DATA
GPS is connected to hardware serial (FTDI pins) with 5V, GND, RX, TX
The total cost could be as low as 13$:
Arduino Pro Mini (2.68$)
GPS Module 9.13$
You can find the code on github:
https://github.com/SamuelBrucksch/diy-frsky-gps
Current features:
- Lat / Lon
- GPS Alt
- Sats
- Fix Type
The Fix Type is read from GPGGA sentences. Following fix types exist:
0 - no fix
1 - GPS fix
2 - DGPS fix
Fixtype and Satellites are transmitted over Temp2 in the following way:
Sats: 7
Fix Type: 3
Temp2 = Sats * 10 + Fix Type = 7*10 + 3 = 73
In opentx you can easily extract the values like this (e.g. with LUA script):
Sats = Temp2 / 10
Fix = Temp2 % 10
Rangarid is offline Find More Posts by Rangarid
Old Mar 24, 2015, 10:25 PM
mamacher is offline
Find More Posts by mamacher
mamacher's Avatar
Joined Aug 2013
I can't wait to give it a try, I've used an Arduino/GPS as a data logger a while ago on my quad. Would this work feeding a Crius AIO Pro 1.1 GPS info, or is it a completely different stream.
mamacher is offline Find More Posts by mamacher
Old Mar 25, 2015, 01:32 AM
Rangarid is offline
Joined Aug 2010
This converts GPS data into frsky telemetry. Criuas AIOP does not need any converter for GPS:
http://fpvcentral.net/2013/03/crius-...ted-for-mw2-2/
Mini-HowTo low cost diy frsky gps hub dave1993 Radios 107 Nov 21, 2014 05:25 PM
Discussion low price GPS module to use with Arduino guy1a DIY Electronics 7 Apr 20, 2012 01:02 PM
Build Log DIY Head Tracker - Low budget jberthing FPV Talk 6 Mar 22, 2012 06:59 PM
Help! diy low budget head tracking barok FPV Talk 3 Jan 31, 2010 02:22 AM
