Old Apr 04, 2014, 01:28 PM
Norway
Joined Jul 2008
Transport case/box
anyone who remembers a post with some homemade transport cases with yellow and red composite glider in it? Believe they were made out of plywood.
Visper is online now Find More Posts by Visper
Old Apr 04, 2014, 01:50 PM
Bad command or file name
Imageek2's Avatar
United States, CA, Corona
Joined Jan 2013
Is it this one?
http://www.rcgroups.com/forums/showt...e#post27973292
Tom
Imageek2 is offline Find More Posts by Imageek2
Old Apr 04, 2014, 02:14 PM
Norway
Joined Jul 2008
No,not quite,but it helps a lot.I'm about to make my own. Wanted to see the layout in the case.I think the one I saw earlier were made for a nan shadow or something.
Thank you very much anyway.
Old Apr 04, 2014, 02:31 PM
Sarasota, FL
Joined Jan 2006
Case
I think you are referring to a yellow Supra for sale that came with it's own wood case. Looked really good. You might try the "for sale section" and lookup used Supras. Good Luck .
Phil
podrieger is offline Find More Posts by podrieger
Old Apr 04, 2014, 03:07 PM
Norway
Joined Jul 2008
I'm sure it wasn't a supra,I've tried to search for it a long time but can't find the post. But I think it was very close to the one listed before.But the fixing of the center and tips were a little different,and think it was foam of some sort inside.
Old Apr 20, 2014, 10:45 PM
John Walter's Avatar
USA, IL, Naperville
Joined Feb 2003
It's not plywood, but here is one I built:
http://www.rcgroups.com/forums/showt...light=ship+box
I don't use it any more, so I plan to list it for sale.
John Walter is online now Find More Posts by John Walter
Old Apr 21, 2014, 12:59 AM
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
I think you might be thinking of the "Rashguard" thread? It is a plywood box for F3X models.
http://www.rcgroups.com/forums/showthread.php?t=2138600
EDIT - I just saw the other link which is the same that I posted. A different box that is currently for sale is presented by an RCG member here named "Kin." The case is only $158 US. Shipping from HK seems to be about the same price as the case itself. Even with shipping it seems like a very good deal
Avaldes is online now Find More Posts by Avaldes
Old Apr 24, 2014, 11:44 PM
Norway
Joined Jul 2008
Some thoughts along the way....
I quickly changed my mind about using plywood when I saw the ones made of corflute. They were so easy to make and light.I contacted a coreflute dealer here, and he only delievers transparent coreflute, and the pieces were 2x6 meters.Price is approx $315 a piece,so I guess I'm back to the plywood idea again.
Old Apr 25, 2014, 12:07 AM
Joined Jul 2004
transportation box
Metal vs wood vs coroplast.
If travelling overseas...
Wooden box
The custom of some countries require quarantine/pests control for wooden boxes so you may need to have fumigation procedures for the sealed boxes with the model planes packed in it before shipping , lots of admin work before you fly for competition. Wood is xray permeable that you pass the custom quickly.
Metal box: durable , resuable. But very likely to attract the custom curiorsity to open it whether you ship the box or hand carrying it on the passenger planes. So a TSA friendly locking system is preferred.
Plastic/ coroplast box . Good material but need to build strong and rigid. The Japanese F3K team used such with great success.
polar bear is offline Find More Posts by polar bear
Old Apr 26, 2014, 12:37 AM
belouder's Avatar
Seattle
Joined Aug 2005
I built a case for a yellow and black Supra Pro Comp. It was a prototype for what I'm now building for folks called "Rashguard". See the thread elsewhere here.
BK
belouder is offline Find More Posts by belouder
Old Apr 30, 2014, 12:02 PM
Norway
Joined Jul 2008
I'm 100% sure it was not a supra in the case I saw. The case was quite similar,but the tips was fixed with short clamps,not stretching over the hole tip.
Too bad I cant find it or I 'll show you.I had the pictures on my pc, but got lost because of a faulty harddrive
Old May 06, 2014, 09:49 AM
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
IF you are making cases for car transport then the rashguard is the best solution - Brian will make you a proper hard case.
The product sheeting the JPN team used for an airline capable case was poly carbonate sheeting (hurricane protection) I have some of that myself. ITs much more expensive than 3/8 sign board which I used for my case for Turkey and South Africa -
You can get Coroplast sign board for about $100 for two sheets and if you build it with enough extrusions and a center flute you will be able to stand on it when its done. Also the box full of 5 planes will still be under 50 lbs which is the typical max weight of most airlines before they ding you for "overweight" fees.
I decided to use clear polycarbonate this go around - yes its more expensive but so are the models in it now The case is about 5% of the cost of the models in it.
Also the clear aspect might help security in their search for nefarious materials since they can see everything...
Wooden box
webbsolution is online now Find More Posts by webbsolution
Discussion Transport cases? Free Indoor Pattern/F3P 37 Apr 01, 2014 09:53 PM
Cool Winch Transport Case wsmorton Sailplane Talk 1 Jan 19, 2014 11:12 AM
Discussion Mini Quad transporting case?? big_poppa4904 Mini Multirotors 3 Dec 28, 2013 11:57 AM
Mini-HowTo Tips for How to Make a Finished Airplane Storage/Transport Box Chophop The Builders Workshop 17 Oct 13, 2013 07:59 PM
Discussion RC Ship Transport Case/Box seadog985 Dock Talk 27 Feb 07, 2012 12:36 PM
