Old Oct 22, 2012, 04:23 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Yippee!
NEW 3in1! 3way Video switch, RC Shutter, High current switch for FPV & AP
Hi Guys,
I want to present you small multifunctional device I have made for FPV and Aerial Photography. I call it RC Camera Controll (RCCC).
RCCC has following features:
  • 3 Channel RC Video Switch (switch one of 3 video inputs to video output)
  • High current LED switch output (Strobe and Headlights)
  • RC Camera shutter control (Focus, Shutter and GoPro mode)
  • LiPo battery low voltage alarm
  • 2 Channel mirroring from sum PPM stream for Pan/Tilt
  • Sum PPM or 3 PWM input control from RC receiver
You can buy some of this stuff here:
It is small 23mm x 40mm (including connectors) board weighting approximately 8g with cable that combines 3 devices: Camera shutter, Video switch and High current switch. It is controlled with sum PPM or regular servo signals from RC receiver.
3 CHANNEL RC VIDEO SWITCH
You can use 3 source video switch for example to switch between flight camera, GoPro camera and back view camera in your FPV plane or multicopter.
LED RC SWITCH
You can use high current (up to 2A) switch to control LED stobe and Headlight (1W...10W) LEDs and also have low battery warning indicated on Headlight LED's.
RC SHUTTER
Shutter is compatible with GoPro HERO1 and HERO2, all C3 plug and 2.5mm plug Canon cameras, Nikon cameras and also many other cameras that have shutter connector.
I have tested GoPro HERO2, Canon 5D, Canon 600D, Nikon D5000.
(Shutter function with GoPro camera operates as On/Off switch. You must set GoPro to One Button mode to start recording when turned On)
You can use Shutter controll to turn ON GoPro camera while in flight to record only needed footage and turn OFF before landing.
GoPro HERO 3 Silver and Black can be turned ON but not OFF. I have heard that White can also be turned OFF (not tested).
I also have Multifunctional GoPro cable with 3 functions:
  • Video out
  • Charging of GoPro in flight (or fly without battery)
  • Turn on/off GoPro when connected to RCCC board (Use OneButton mode to start recording after power ON)
Using live video from GoPro is not recommended as primary video for FPV because it has some delay.
It works with HERO1,2,3,3+.
With HERO 3 you can get video out, turn it ON (but not OFF) and charge camera (with latest firmware update).
If cable plugged in HERO2 new playback menu item appears and you can play captured videos.
GoPro camera compatibility chart
Here is video where I tried to show all features of RCCC
RCCC V1.0 (1 min 11 sec)
Strobe function added in v1.1
RCCC v1.1 High Current Switch functions (0 min 28 sec)
Here I am using video switch function for FPV
Video Switch (1 min 17 sec)
GoPro HERO2 mutifunctional bus cable demonstration with RCCC device (0 min 44 sec)
Please feel free for any questions.
kristaps_r is offline Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
HELPFULL INFORMATION
Setup when using regular servo channel outputs (PWM) RCCC V2
RCCC V2 Setup - regular servo channel control (PWM) (3 min 52 sec)
Setup when using sum PPM RCCC V2
RCCC V2 Setup - regular servo channel control (PPM) (3 min 49 sec)
Setup when using regular servo channel outputs (PWM) RCCC V1.X
RCCC v1.0 Setup - PWM (1 min 27 sec)
Setup when using sum PPM RCCC v1.1
RCCC v1.1 Setup - PPM (1 min 9 sec)
Setup when using sum PPM only RCCC v1.0
RCCC v1.0 Setup - PPM (1 min 11 sec)
Old Oct 22, 2012, 05:09 PM
My Karma ran over my Dogma
fireslayer26's Avatar
United States, FL, Jacksonville
Joined Feb 2010
Very cool and well priced! This would be really good for aerial photography with a multi-rotor. Could fly into position with the FPV cam, turn on altitude hold and position hold, then switch to aerial cam that you could have on a gimbal system and position it how you like then take a picture.
fireslayer26 is offline Find More Posts by fireslayer26
Old Oct 22, 2012, 08:32 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
What is the current capacity of the switch?
Hugo
Hugeone is online now Find More Posts by Hugeone
Old Oct 23, 2012, 01:48 AM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
I use N channel mosfet that is rated not less than 8 amps, but I haven't tested it with really heavy loads like this. I will try to do that using automotive headlight bulb.
Usually pin headers and connectors are rated for 3 amps. 3 amps should be no problem for this board.
I will post the results when I finish testing.
Kristaps
Hugo
Old Oct 27, 2012, 07:50 AM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
So I tested RCCC with 60 Wat automotive bulb that is 5Amps at 12V.
After 10s switch became hot. I didn't tested longer than 30s (maybe some day in fire safe place)
RCCC v1.0 5amp current test (0 min 23 sec)
I think 3 Amps continous will be OK (will find 36W bulb to test).
And if you need 60W for something, you can use it for short times or added heatsink
Kristaps
Hugo
Old Oct 28, 2012, 01:46 PM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Can you post some pictures of your camera connectors, for example to a gopro?
boopidoo is offline Find More Posts by boopidoo
Old Oct 28, 2012, 01:55 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Right now I have picture of my first GoPro cable, that has pretty big connector.
I Just got other connectors that are smaller and will solder cable next week and will have photo.
I will make photos of all available cables as soon as I will have them assembled.
Old Oct 29, 2012, 10:15 AM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Don't have good lights for photography but here are cables for GoPro and Canon with C3 connector.
Hi resolution pictures in first post.
All shutter cables have 3 pin servo female connector that connects to RCCC board like in this picture:
P.S. More pictures will come.
Kristaps
Old Oct 29, 2012, 10:19 AM
mike_o's Avatar
Denmark, kbh
Joined Jan 2012
Be careful: The resistance of a light bulb is strongly temperature dependant. When the filament is cold, the resitance could easily be half or less of the resistance when white hot. The initial current of a 60W, 12V light bulb could be 10-15A.
Nice device you have designed, BTW.
mike_o is offline Find More Posts by mike_o
Old Oct 29, 2012, 12:16 PM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Ok, so the gopro cable is only on/off? What about rec on/off and AV out? Is this possible with some kind of connector?
Old Oct 29, 2012, 12:35 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
GoPro cable is used to turn GoPro On or Off because GoPro connector interface does not have record pin. All existing solutions I know for GoPro use power On/Off.
To start recording after power on you have to enable One button mode.
Kristaps
Old Oct 29, 2012, 03:08 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
I am thinking also about AV out function using GoPro accessory connector, but at the moment don't have time for that.
Old Nov 15, 2012, 03:01 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
New Batch
Hi,
Finally I have new batch of RCCC boards.
This time it is little improved:
  • Power source solder jumpers on bottom of board changed to connect 5V from RC receiver to switch output. Now you can switch 5V LEDs without battery connected.
  • Added strobe function to Switch output. Switch now has 3 states: OFF, Strobe, Steady ON.
  • Ability to disable some of functions (Shutter, Video, Switch) when using sum PPM. If you don't have enough channels you can use only one or two of them.
Boards are labeled RCCC V1.1
Cables also have just arrived and I have shutter cables for Canon with C3 and 2.5mm connectors, Nikon with N3 connector and GoPro 30pin connector.
Kristaps
Old Nov 16, 2012, 10:03 AM
robineche's Avatar
france
Joined Jan 2007
Can I use this board with a MK Flight controller ?
( wiring on a servo output for instance )
Your solution is cheaper than the GentleWIRE cable to control my canon 600d.
robineche is offline Find More Posts by robineche
New Product New Panasonic GH2(and others) RC Shutter in stocks! MelihK Aerial Photography 11 Jun 10, 2013 08:53 AM
Yippee! NEW 3 IN 1 RC Shutter, 3 Video switch, High current switch for AP & FPV kristaps_r Aerial Photography 2 Dec 04, 2012 02:40 PM
New Product New high Current Switch for Electric Flyers divebot Product Announcements 0 Sep 02, 2012 07:27 PM
For Sale Brand NEW RC Head Tracking High-quality ALL-IN-ONE wireless video goggle FPV kit syst John li FPV Equipment (FS/W) 1 Aug 04, 2012 02:02 PM
Sold RC Shutter, RC Controlled Switch....NEW crd FPV Equipment (FS/W) 1 Apr 12, 2012 08:19 PM
