Old Jan 26, 2014, 02:00 PM
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
Question
Outboard Pass Transistor
I need to increase the current output of an LM338T Voltage regulator. I've found some circuits that suggest an "outboard pass transistor", and they look like they will do the job, but they don't list an actual part number for the transistor, just the schematic symbol that shows a PNP transistor.
My question is this, I have some NPD6020P transistors availible, would they work OK in this application? They are logic-level MOSFETs, here's the data sheet , but I don't know enough theory to know if they would be suitable. Or would I be better off with something else?
Thanks for any help, guys!
dmccormick001 is offline Find More Posts by dmccormick001
Old Jan 26, 2014, 02:59 PM
Joensuu, Finland
Joined Mar 2002
Nope, FET doesn't work, it needs to be bipolar. Just about any power PNP will do.
jkettu is offline Find More Posts by jkettu
Old Jan 29, 2014, 08:24 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
try a MJ 4502 ... or TIP 36 or BD 250
that should do it ...
or also use 2 or 3 338 in // ( see 338 or 350 datasheet for the balancing circuit )
Alain
Acetronics is offline Find More Posts by Acetronics
Help! Hitec Flash 5 transistor identification scarabrae Radios 0 Jan 07, 2014 01:39 AM
Discussion Problem Lawmate 1.2 Ghz what kind of chip (output transistor) Sagitarrius FPV Equipment 0 Jan 04, 2014 12:27 PM
Question LED driver transistor circuit for Arduino bdelapen DIY Electronics 24 Dec 04, 2013 01:15 AM
Sold Vintage Outboard Cabin Cruiser Fiberglass Hull and Deck for K&B Outboard? Tollytime Boats (FS/W) 2 Jul 25, 2012 03:58 PM
Wanted looking K&B 7,5 outboard engines.....or OS 3,5cc outboard engines. fekete csaba Boats (FS/W) 4 Mar 10, 2010 01:39 PM
