Old Sep 08, 2014, 05:14 PM
Alex
Datos's Avatar
Ukraine, Kyiv city, Kyyiv
Joined Feb 2012
I said it many times before and right after discussing this matter with KDS reps. - KDS Innova line is still available for sale but its absence on the shelves is explained by the newest trend of all dealers to go with Agile brand which gives more profit and generates orders. Nevertheless, there are plenty of Innova parts and kits on KDS warehouse... the real problem is how it might reach the end user if dealers are no longer placing their orders and KDS does not have a potential|interest in the direct sales. I recommnded KDS to think of establishing|cooperating with at least one local (Chineese) shop with the role and rights to aggregate all available Innova parts|kits and to sell|send these parts abroad. KDS reps. told me that they would think about it.
Long time no see....
For now, Shelly from KDS said that she would help anyone (sell parts|kits directly) who would contact her directly over email or facebook account message. I've posted her email in this thread.
Any other questions?
Datos is offline Find More Posts by Datos
Old Sep 08, 2014, 05:23 PM
Alex
Datos's Avatar
Joined Feb 2012
Originally Posted by Atomic Skull View Post
Anyone have the newer Agile style tail grips that KDS is shipping for the Innova line? I have a couple questions about them.
Are they sloppy like the old style Innova grips or did they fix that?
Can you adjust the preload with the nylock nut the way you can on a Kasama tail?
I've had a maiden for a person with Agile 5.5 lately. I haven't noticed that tail grips are somehow different or supreme to Innova 550,600,700. It was exactly the same hub and tail grips with the same flaw - out of balance from the box. Some spacers should be placed between hub sides and tail grips in order to balance it right... Moreover, I have seen the assembled Agile 7.2 and it also had the same tail hub and grips design.
Old Sep 08, 2014, 11:23 PM
Atomic Skull's Avatar
Joined Dec 2011
Do you mean there is axial play in the grips or that the two sides of the hub are different lengths?
Atomic Skull is offline Find More Posts by Atomic Skull
Old Sep 09, 2014, 05:02 AM
Alex
Datos's Avatar
Joined Feb 2012
I've never examined the hub to understand whether it differs in length on its sides. The problem that I see - is that there is grips play on the hub even if nuts are tightened. Therefore, some spacers should be introduced between a grip and hub to eliminate this play. This, usually, resolves vibrations...
Old Sep 09, 2014, 01:48 PM
x5heli's Avatar
United States, TX, Pearland
Joined Aug 2012
I hope all the kds retailers and distributor continues carry parts. It's a good bird to become something u know. But if Noone in usa carry innova, i will do it if they let me become distributor.
x5heli is offline Find More Posts by x5heli
Old Sep 09, 2014, 05:10 PM
Joined Dec 2011
Ok so it's just lateral play on the grip then.
EDIT:
Do the grips really use a 7x9.8x0.5 shim between the radial and thrust bearing as shown in the manual? That seems backwards compared to other tail grips. Tail grips typically use a shim that matches the O.D of the bearings to prevent axial load on the radial bearing and it seems to me that using one that matches the I.D. would have the opposite effect (excepting grips where the thrust bearing is in the center where it *is* normal to use a shim that matches the I.D. of the bearings)
Never mind they made a mistake in the Agile 5.5 manual (which is what I looked at for the details on these grips), the diagram says 7x13x3 but the bearings are actually 5x10x4. Interestingly the parts list next to the diagram also says 5x10x4.
Old Sep 11, 2014, 08:59 AM
Alex
Datos's Avatar
Joined Feb 2012
Shelly just posted this
Old Sep 11, 2014, 05:10 PM
Joined Dec 2011
Link unavailable. What did she say? Just received my box of spares from her, including hard to find 680 servos
deonjams is offline Find More Posts by deonjams
Old Sep 11, 2014, 05:17 PM
Alex
Datos's Avatar
Joined Feb 2012
Link works fine for me.
Anyway, she posted the followng:
"Don't worry about parts of your INNOVAs if you are crazy for it!!
We have tons of stock and having a beat-the-heat DISCOUNT on the kits!! Just go to your local store or contact us!"
Old Sep 11, 2014, 05:24 PM
Joined Dec 2011
Thanks, and good news. Pity I just bought a spare 550 kit from HK. Don't have permission for that page, not a FB regular and just email her directly for items
Old Sep 23, 2014, 12:50 AM
Joined Dec 2011
It looks like KDS has changed the tail rotor hub. The hub on the set of grips I received from HK today was such that you can damage the bearings if you over tighten the nylock nuts. They arrived with zero play, took them apart to check assembly and put them back together and the grips were locked up. I then realized that they are like Kasama grips where you're only supposed to tighten the nylock nut enough to remove axial play but by then I needed a new set of radial bearings.
Finish is not matte, they are exactly the same grips as the KDS Agile ones.
Discussion Kds innova 550 flb lenachen Electric Heli Talk 16 Dec 30, 2011 01:10 AM
Discussion KDS Innova 600 FBL - what Flybarless system? JeremyT Large Electric Helis 9 Dec 23, 2011 04:57 AM
Discussion KDS Innova 700E Unboxing rcgirl99 Electric Heli Talk 14 Nov 29, 2011 09:46 PM
For Sale WTT: Trex 600N FB/FBL for Trex 600E/550E FB/FBL RCDXER Aircraft - Electric - Helis (FS/W) 0 Oct 01, 2011 07:19 AM
