Old Aug 30, 2011, 04:19 PM
maddog7's Avatar
Joined Jan 2004
Anyone have good UK source for lite ply?
As above, anyone have a good UK source for lite ply? Looking to scratch 30/50/140 size electric 3D (hopefully) airframes. But the only place I can see only does 3/32 and 1/8.
I've searched RCG with " lite ply UK" and "ply UK" and found nuttin'
Any suggestions welcome.
D
maddog7 is offline Find More Posts by maddog7
Old Aug 30, 2011, 05:43 PM
Staffs, UK
Joined Nov 2003
So what sizes are you looking for ?
SLEC http://www.slecuk.com/catalogue/Lite-Plywood.html do 2mm, 3mm and 6mm
Balsa Cabin http://balsacabin.webs.com/plylite.html do 2, 3, 4 and 6mm
Balsamart http://balsamart.co.uk/store/index.p...ex&cPath=46_77 do 3/32, 1/8 and 6mm.
That's just the first 3 wood suppliers I tried, there may well be others.
Steve
slipstick is online now Find More Posts by slipstick
Old Aug 30, 2011, 05:44 PM
Cromer,Norfolk, UK
Joined Nov 2006
SLEC has it, good folks to deal with as well and their wood quality has always been excellent when I've used them;
Beat me to it slipstick
MCarlton is offline Find More Posts by MCarlton
Old Aug 30, 2011, 06:12 PM
maddog7's Avatar
Joined Jan 2004
Thanks fellas,
Thats absolutely spot on. I was looking for recommendations I suppose since I'm not sure how widely the quality varies.
That really helps though, I'll give them a good look.
Cheers
D
Old Aug 30, 2011, 07:03 PM
Cromer,Norfolk, UK
Joined Nov 2006
If SLEC's liteply is the same stuff they make their kits out of, its top notch.
That said, liteply might not be the best choice for the 30 size model as its pretty heavy, the 2mm stuff which is as thin as it gets weighs about the same as 3/32" balsa so that might be worth considering.
Old Jul 13, 2014, 04:36 AM
Essex BOF's Avatar
Joined Sep 2009
I find the Lite Ply used by SLEC to be brittle and would like to get what is called Poplar Lite Ply, very white in appearance, that used to be widely available.
Balsa Cabins is the same as Slec's as it seems are most of the supply in the UK
Anyone any clues as to whether it is available in 1/8th/3mm X 36" long?
Essex BOF is offline Find More Posts by Essex BOF
Old Aug 05, 2014, 01:36 AM
Joined Oct 2012
I use Inwoods for most of my wood supplies, as there's not a single model shop in my area. Always had good service off them - even to the point of letting me keep stuff they'd accidently added to my order by mistake!
Here's the link to their ply section, might be something there you like and they do 36", 48" and even 60" sheets;
http://www.inwoodmodels.com/index.ph...oller=category
Regards
Harry
Harry Rule is offline Find More Posts by Harry Rule
Discussion CF tube and/or ply strips source? ReikiMaster Foamies (Scratchbuilt) 2 Aug 31, 2011 06:12 AM
Discussion Good UK source for breakout boards? Katch Multirotor Talk 0 Aug 08, 2011 06:20 AM
Discussion UK source for self-adhesive copper tape? RobinBennett Night Flying 0 May 07, 2011 02:54 PM
Discussion CA Hinges anyone have a good source for them............ mtdoramike Hot Online Deals 7 Nov 25, 2010 11:32 AM
Discussion Anyone have a good source for carbon rods and tubes? Argyle Foamies (Kits) 15 Mar 22, 2006 08:50 PM
