Old Nov 04, 2013, 06:40 PM
jpurcha's Avatar
Canada, MB, La Salle
Joined Sep 2004
I would hope so. The manufacturing costs in China would be a lot cheaper. A company has to be willing to put ou the money for the injection mould die for the component parts. But, it's easier for them to be laser cut the parts and supply a complete arf.
Jim
Originally Posted by Captain Dunsel View Post
Next thing you know, HobbyKing will have one.
CD
jpurcha is offline Find More Posts by jpurcha
Latest blog entry: How time flies
Old Nov 05, 2013, 10:50 AM
USA, NY, Burnt Hills
Joined Aug 2008
I have one needing some work and am looking for a tracing, dimensioned drawing, or whatever to make a rib indexing tool. Or if someone has one they would sell.
Bill
WinglessB is offline Find More Posts by WinglessB
Old Nov 05, 2013, 03:37 PM
War Eagle!
sneasle's Avatar
United States, AL, Huntsville
Joined Sep 2006
Can you remind me what the indexing tool looks like? Most of my jig is still boxed up from my last move, but I might be able to find the stuff.
sneasle is offline Find More Posts by sneasle
Old Nov 05, 2013, 08:29 PM
Joined Feb 2008
Wingless,
Go back to post #87. If this what you are looking for, I can send you pdf drawings.
GeneH
Alpha35 is offline Find More Posts by Alpha35
Old Nov 06, 2013, 10:15 AM
Joined Aug 2009
Gene, this is precisely what is being discussed. Would like to send you an e-mail address to send the .pdf file to. Is that OK?
gumppy is offline Find More Posts by gumppy
Old Nov 06, 2013, 03:01 PM
Joined Feb 2008
gumppy,
PM me your email address.
Old Nov 17, 2013, 07:52 AM
Jim in the Desert
cloud_9's Avatar
United States, NM, Las Cruces
Joined Aug 2007
What's the status on this in 2013?
I've been waiting for a complete one to pop up on ebay or RCGroups...they sell for 300 and over sometimes if NIB.
cloud_9 is offline Find More Posts by cloud_9
Latest blog entry: Drill Sizes
Old Nov 17, 2013, 05:15 PM
jpurcha's Avatar
Joined Sep 2004
I guess you mean a 2013 brand new one. Probably ain't going to happen. The originator of this thread hasn't logged on to RCGroups in over 2 years.
Jim
Old Nov 17, 2013, 08:42 PM
Jim in the Desert
cloud_9's Avatar
Joined Aug 2007
Thanks. Well at least I scored one on Ebay, but it's missing the rib indexing tool for locating the two holes in ribs. Hopefully I can find pics good enough to make a good enough drawing to let me make one.
Jim
Old Nov 17, 2013, 08:55 PM
Jim in the Desert
cloud_9's Avatar
Joined Aug 2007
Originally Posted by Alpha35 View Post
I made an accurate CAD drawing of an original Rib Template Jig, with the intent of making
a duplicate for an incomplete Adjusto Jig I picked up at a garage sale. Not too hard to make
(including a few improvements).
GeneH
Gene, I just PMd you to see if you still have this.
Jim
Old Nov 17, 2013, 09:02 PM
Jim in the Desert
cloud_9's Avatar
Joined Aug 2007
Having picked up garage sale A-Justo-Jig that was missing the rib indexing
template, I decide to make one using measurements taken from one I had sold.
The original 3"x15" base was made of 1/4" tempered masonite, with a 1/8" thick masonite centering guide plate attached to the left end. On the right end was a sliding 1/8" inch thick injection molded plastic U channel with a 1.5" wide 1/32"
deep channel on its top surface used to center the right end of a 1/32" thick, 1.5"
wide, 15" long plastic hole punching guide (a pair of 5/32" dia. holes, 2" o/c).
The left side of the plastic strip had a centered 3/32" x 5" slot fixed by a 3/32"
screw centered in the left side positioning guide.
Since the original jig's 1/4" thick base had developed a 3/8" bow over the years,
I decided to make the new base out of 3/4" MDF. I made the left and right end guides from 1/8" x 3" aluminum channel with legs cut back to 5/8" depth. A .040" deep, 1.5" wide recess was milled into the top of the right guide. The left guide was drilled and tapped to accommodate pressure clamping knob w/a #6 32 thread. The 1.5" x 15" plastic strip was cut from 1/16" clear polycarbonate
with a milled .125" x 6" slot and pair of 5/32" guide holes.
So if all else fails in locating a rib hole indexing jig, you can always make one.
Attachments show the original and the homemade replica.
Gene H
Thanks Gene, with that, I can make a trip to the local machinist, and get one made to replace my missing one, that will last a lot longer.
Jim
Old Nov 17, 2013, 09:13 PM
Jim in the Desert
cloud_9's Avatar
Joined Aug 2007
Wingless,
GeneH
Gene, would love those PDF drawings, AND the CAD. I don't ask for much.
Jim
Old Nov 18, 2013, 03:11 PM
Joined Feb 2008
Jim,
PDF's sent. GeneH
Old Nov 18, 2013, 07:18 PM
Jim in the Desert
cloud_9's Avatar
Joined Aug 2007
Jim,
PDF's sent. GeneH
Gene, I got the PDFs and the pictures as well. Thanks so much, I should be able to reproduce one now.
Jim
Old Nov 20, 2013, 10:43 PM
bigdad1975's Avatar
United States, TX, Cypress
Joined Aug 2011
I have the Full house set-up that's like new. If anyone needs pics or specifics I can help
bigdad1975 is online now Find More Posts by bigdad1975
Wanted A-Justo-Jig vintagesailplnr Aircraft - Sailplanes (FS/W) 5 May 23, 2010 08:40 PM
For Sale for sale The a-justo-jig wing jig slo poppy Aircraft - General - Miscellaneous (FS/W) 13 Apr 18, 2010 02:44 AM
Sold Adjusto-Jig wing assy jig LouE Aircraft - General - Miscellaneous (FS/W) 2 Apr 14, 2010 08:41 AM
Wanted A-justo jig rib locators rayjay Aircraft - General - Miscellaneous (FS/W) 1 Feb 04, 2010 06:22 PM
eBay: Complete A-Justo Jig set RickTatem Aircraft - Electric - Airplanes (FS/W) 0 Apr 09, 2002 04:59 PM
