Old Feb 03, 2012, 07:14 AM
Winging it Ō>
leadfeather's Avatar
Joined May 2006
Idea
4 bar mechanism
Here is an idea that may be helpful for bicopters/bicopter type VTOLs. Using a 4 bar mechanism for pitch control
By using a 4 bar mechanism to tilt the motors, it is possible to place the "apparent pivot point" called the "instant center" well above the copter for more effective pitch control.
leadfeather is offline Find More Posts by leadfeather
Old Feb 04, 2012, 02:52 AM
VTOLicious's Avatar
Austria
Joined Oct 2007
Interesting thoughts...sorry, but I donīt quite follow
Can you make a sketch that illustrates the applying forces and moments?
Cheers, Michael
VTOLicious is offline Find More Posts by VTOLicious
Old Feb 04, 2012, 02:55 AM
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
interesting idea, cant wait to hear how it works in practise.
matwelli is offline Find More Posts by matwelli
Old Feb 04, 2012, 05:47 AM
Winging it Ō>
Joined May 2006
Cheers, Michael
The sketches below might help clear it up a little.
In interesting note is that the motor translates relative to the cg which equates to weight shift. If the side links of the 4 bar mechanism were parallel to each other, there would be no tilting of the the thrust but there would still be the weight shift component.
As drawn the mechanism gives the tilt and weight shift effects together.
Old Feb 04, 2012, 06:36 AM
VTOLicious's Avatar
Austria
Joined Oct 2007
Well, your IC is the geometrical intersecion of the 2 side links. But what makes you think the whole aircraft pivots around the point what you call the "instant center"?
I donīt see any benefit...by now
Regarding the weight shift: If you donīt balance the motor-nacelle youīll always have some weight shift when its pivoting relativ to the fuselage.
Old Feb 04, 2012, 08:08 AM
France
Joined Nov 2008
I understand the leadfeather idea, I've tried a lot of mechanism on my tricopters yaws.
The main point for our bi/tri tilt mechanism is to reduce the distance between the tilt center and the prop/motor lift center.
But the four bar mechanism could be usefull to reduce (or to "fine tune") the distance between lift axis and CG/AP of the VTOL.
(I appologize for my poor "mechanical" english)
lebrett is offline Find More Posts by lebrett
Sold 4" Ratchet Bar Clamp/Spreader for modelers unclegeorge Aircraft - General - Miscellaneous (FS/W) 2 Dec 17, 2011 08:45 AM
Sold 4" Bar clap for the modeler unclegeorge Aircraft - General - Miscellaneous (FS/W) 1 Dec 17, 2011 01:16 AM
Sold 4" Ratchet Bar Clamp/Spreader for modelers unclegeorge Aircraft - General - Miscellaneous (FS/W) 3 Jul 24, 2011 11:03 PM
For Sale Mikado V-bar black 4.0 Slash Crazy Aircraft - Electric - Helis (FS/W) 0 Jul 12, 2011 06:40 PM
