Old Jul 07, 2001, 07:57 PM
Joined Apr 2001
Radioshack motors
Has anybody checked out the cheap radioshack
motors?
Mark
Henchman is offline Find More Posts by Henchman
Old Jul 07, 2001, 09:49 PM
buckeyes1997's Avatar
columbus, oh, usa
Joined Jun 2001
i bought the cheap 4.99 version, but am not impressed. its close in size to the 400s but not nearly as powerful.
buckeyes1997 is offline Find More Posts by buckeyes1997
Old Jul 07, 2001, 10:07 PM
Dave Segal
Philadelphia PA USA
Joined Jun 2001
You can get the full specs on this and other tiny motors at Dick Miller's website at www.empsinc.com
Dave Segal
Dsegal is offline Find More Posts by Dsegal
Old Jul 07, 2001, 11:27 PM
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
I bought two recently. They were about $3.50 and there were two voltages. One was rated for 9-18volts and the other 12volts. I used the 9-18volt one in my Skimmer 400 sailplane as an experiment. It weighs 1.8oz and has the same mounting pattern and shaft size as a speed 400 so it bolted right in. On 8 cells with a 7x6 prop direct drive it would barely fly the plane. I think it was using about 2.5Amps at about 8.5volts. The trouble with these motors is that they are wound for higher voltage operation than we need for our planes. The brushes are as big as the ones in a speed 400 but you'll burn the fine wire windings out long before you ever get enough current to damage the brushes. It would be great if they had one this size but with fewer turns and larger wire for the 6V range.
Gerald is offline Find More Posts by Gerald
Old Jul 08, 2001, 12:04 AM
Joined Apr 2001
The 3v scream with a cox push on prop (about 3") and 9.6. I'll get back to you on life span... maybe a nickel rocket?
fisher is offline Find More Posts by fisher
Old Jul 08, 2001, 03:12 AM
Mikey_Flies's Avatar
Edmonton, Alberta, Canada
Joined Oct 2000
And you get a fireworks show for free if you watch the brushes
Mikey_Flies is offline Find More Posts by Mikey_Flies
Old Jul 09, 2001, 12:16 AM
Professional Dork
Randy S's Avatar
Winchester, Kentucky
Joined Jul 2000
Gerald,
Isn't a 7 x 6 prop used in direct drive a bit much, even for a regular Speed 400 motor?
Randy S is offline Find More Posts by Randy S
radioshack motors drummermike85 Parkflyers 6 Jan 11, 2002 09:11 PM
radioshack motors drummermike85 Foamies (Kits) 0 Jan 11, 2002 10:45 AM
