Old Mar 28, 2015, 10:47 AM
kak8 is offline
Find More Posts by kak8
kak8
Joined Jun 2005
Alegro Lite tip
Hello
I build the wing tip at the moment and waiting for the end rib to cure.
Next step will be to glue lower sheeting.
I have seen people are doing some strange things with the sheeting at the end part of the tip. I just sanded the bottom flush with the ribs, for the sheeting.
But the top sheeting - there is no bonding area at the end. Just the edge. And the spar.
Should I glue a little balsa and sand it down, to create a little triangle and some more bonding area?
Because I will sand through the sheeting when finishing the wing.
kak8 is offline Find More Posts by kak8
Old Mar 28, 2015, 02:42 PM
leons is offline
Find More Posts by leons
украина , чернигов
Joined Feb 2011
so you can leave but it's better to add a stick of balsa , but the front part of the ending actually superfluous ,I have a front lining strapped to each other
leons is offline Find More Posts by leons
Old Mar 28, 2015, 02:54 PM
leons is offline
украина , чернигов
Joined Feb 2011
something
Old Mar 28, 2015, 04:38 PM
kak8 is offline
kak8
Joined Jun 2005
Thanks.
I will add some balsa under the sheeting.
I must be carefull with the weight. I already have one Alegro wing, made of wood, which weights 400g. I didnīt taper the end of the tip.
Old Mar 30, 2015, 09:03 AM
kak8 is offline
kak8
Joined Jun 2005
What kind of glue is Duco or Ambroid? Itīs recommended to use it to glue the triangle strips, but I canīt find it in my local stores. Does it fill the gap between sheeting and the spar?
Can I use the foaming gorilla glue instead?
I know how to fill gaps, but I want to do it light, so itīs better to stick to the instructions :-)
Old Mar 30, 2015, 04:05 PM
kak8 is offline
kak8
Joined Jun 2005
Ok, Iīve figured it out. The gap doesnīt matter. It will be covered with coverng film.
There are much bigger gaps, like between the ribs :-)
Old Mar 30, 2015, 05:05 PM
leons is offline
украина , чернигов
Joined Feb 2011
the biggest drawback aesthetic appearance when the lower spar sticking out and I drowned 1.5 mm
http://static.rcgroups.net/forums/at...9102010272.jpg
Old Mar 30, 2015, 05:47 PM
kak8 is offline
kak8
Joined Jun 2005
I guess itīs ok for electric glider or highstart if the spar is a little lower.
This is my first carbon spar. I have never build a spar that stiff :-)
Almost impossible to bend in my hands. Itīs like a steel rod of the same size :-)
But if the weight of the glider is under 600g, thats more than enough for me.
And I donīt have this very thin 0.007" carry through carbon stips, so I had to make a little pocket in the tip and a little joiner.
Old Mar 31, 2015, 09:12 AM
kak8 is offline
kak8
Joined Jun 2005
Thatīs much better. Sheeting support.
Sold Short Alegro Kit Hudley Aircraft - Sailplanes (FS/W) 0 Mar 27, 2015 05:10 PM
Wanted Supra carbon pro lite wing tips VHO Aircraft - Sailplanes (FS/W) 0 Sep 12, 2011 06:34 AM
Wanted Aegea 2m /alegro lite wsnowfall Aircraft - Sailplanes (FS/W) 0 Nov 18, 2008 12:23 AM
Sold Icon Lite right wing tip (damaged) nuevo Aircraft - Sailplanes (FS/W) 1 May 20, 2008 10:47 PM
tips for building lite sgtdirt Free Flight 8 Jun 21, 2005 05:52 PM
