Old Oct 23, 2014, 11:25 AM
stefanoc2 is online now
Find More Posts by stefanoc2
stefanoc2's Avatar
United States, TX, Houston
Joined Aug 2006
RG731BX versus RG712BX
These two receivers seem to have the same number of ports, size, weight and functionality.
The only feature added to the 712 is described as low consumption.
Is the 712 intended to replace the 731. My only complaint with the 731 is that it runs hot.
Stefano
stefanoc2 is online now Find More Posts by stefanoc2
Old Oct 23, 2014, 08:13 PM
pigly is online now
Find More Posts by pigly
PaulG
Newcastle, NSW Australia
Joined Dec 2004
one vs three
I have just got one, the use the same case as the 731b but there is only one pc board in there and no satellites,although a satellite is coming which seems to just have two extra antennas. I think they looked what the others were doing and decided if they wanted to stay in the game they had better do something. The antenna diversity is the clue, using the best signal instead of using three receivers. I am going to put it in one of my F3J planes and see how it goes. I think that although the fuses are 2.4 friendly I'll put the antennas out anyway, just the tip (only 26mm long) not the booster section or whatever it is. My recent 731b came with these antennas too, a bit of a problem in a slim fuse.
The lower consumption must be due to using one rather than three receivers.
pigly is online now Find More Posts by pigly
Old Oct 23, 2014, 08:30 PM
stefanoc2's Avatar
Joined Aug 2006
Interesting. One item that threw me for a loop is the RCJapan website that lists the range of the receiver at 600m while saying the 731 has 1km range.
Please let me know if the new receiver also runs cooler.
Thanks, Stefano
Old Oct 23, 2014, 08:47 PM
Joe W is offline
Find More Posts by Joe W
launch low, fly high
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
I just got some comments on the receiver that suggests very good range performance as compared to the 731 rx (contradicting the listed range from Stefano). As soon as I get one (just ordered one now) I will install it in a plane and provide a report.
Joe W is offline Find More Posts by Joe W
Old Oct 24, 2014, 08:47 AM
stefanoc2's Avatar
Joined Aug 2006
Fantastic, thank you Joe.
Stefano
Old Oct 24, 2014, 01:51 PM
burke757 is offline
Find More Posts by burke757
United States, VA, Norfolk
Joined Sep 2007
Does anyone know if there is any plan to make XBUS compatible with other brands of servos...like Futaba SBUS servos? As of right now, it appears that XBUS is not compatible with other brands of SBUS servos in either Mode A or B without a decoder, which limits its usefulness, unfortunately.
Randy
burke757 is offline Find More Posts by burke757
Old Oct 25, 2014, 12:01 AM
pigly is online now
PaulG
Joined Dec 2004
not near the servos
One thing I learned today whilst installing the receiver in an Aspire is that the fuse servos chatter if you have the antennas anywhere near them. I guess it is the antenna booster picking up any electro-magnetic radiation from the servos and sort of acting like a feed back loop. You only have to move them a little way before the chatter stops.
Old Oct 25, 2014, 11:54 PM
pigly is online now
PaulG
Joined Dec 2004
Good
I went out today with the Aspire with the 712 fitted (both antennas forwards from the receiver, one horizontal on one side of the fuse, the other at 45 degrees on the other). Not a very good install but what I could do in the time. We did a thorough range test at about 40 paces, no problems. I then had three flights in quite weak lift with some strong cores. I got the plane nearly to the limit of my eyesight and quite high (800' -1000'. I would normally get a bit further away and higher at comps but the model is green, my eyes were watering and the sunnies were not optimal for the green wings. However, very solid reception to the furthest limit, very pleased and I won't be taking it out of the plane and will be getting a few more at the price Model Flight are offering them. So the only small problem will be the placement of the antennas.
I will be interested in seeing how Joe gets on with his superior eyesight but I think there will be no problems. So far well done JR, now fix the manual and put some worked examples in it like you did with the 9303.
Paul
Old Oct 27, 2014, 03:20 AM
pigly is online now
PaulG
Joined Dec 2004
Consumption
The 712BX used about half the mAhrs than a 631B or an 831B. 80mAhrs vs 165 mAhr.
Old Oct 27, 2014, 05:05 PM
fredo21 is offline
Find More Posts by fredo21
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
I have attached a copy of the manual to this post.
http://www.rcgroups.com/forums/showp...28&postcount=3
Stuart
fredo21 is offline Find More Posts by fredo21
Old Nov 14, 2014, 11:49 AM
stefanoc2's Avatar
Joined Aug 2006
Any updates on this receiver?
Stefano
Old Nov 14, 2014, 04:12 PM
jyzoom is online now
Find More Posts by jyzoom
jyzoom's Avatar
Singapore (Asia)
712bx
I got a couple of these with me now...
I like to check if anyone have put it into F3F ship yet ?
Before I start changing out mine to 712BX ..
update:
Will not get a chance to fly F3f till the season start in a few weeks.
But I did a bench test conpare to 731 and 831 , the 712bx is definitely not hot comparing these two.
To be safe I have a r01t full range also installed as advice on the manual. Still did not heat up as compare to 731 and 831 hock up with r01t. So far so good.
jyzoom is online now Find More Posts by jyzoom
Old Nov 24, 2014, 09:38 AM
stefanoc2's Avatar
Joined Aug 2006
Joe W posted this in the F3K forum:
"The 712BX receiver seems to work nicely. The benefits are that it does not need a satellite to have downlink capability and that the current drain is lower. I got a bit of reasonable weather today to do some test flying and it appears that it translates my commands to the airplane reliably, even at my eyesight limits. It works very well for F3K once you remove the bulky plastic case."
http://www.rcgroups.com/forums/showt...&highlight=712
Stefano
Old Dec 17, 2014, 12:27 PM
stefanoc2's Avatar
Joined Aug 2006
Received a couple of them today form RCJapan.
I am not clear from the manual if the Remote Antenna for this receiver is the same as the one for the 731BX. Do you know?
Stefano
Old Dec 17, 2014, 12:38 PM
stefanoc2's Avatar
Joined Aug 2006
It may be a totally different module according to this link:
RA02TL
DMSS Remote Antenna for 2.4GHz Receiver (Diversity anttena Type)
http://www.jrpropo.com/english/produ...db_flg=eng_db1
Sold JR XG14 with RG731BX & RG1131B LNIB spookyeng Aircraft - General - Radio Equipment (FS/W) 1 Oct 03, 2014 11:15 AM
Sold JR XG14 Radio & RG731BX DMSS Receiver - Re-Listed & BIG Price Drop!!! Greg Gimlick Aircraft - General - Radio Equipment (FS/W) 0 Aug 21, 2014 11:14 AM
Sold JR XG14 Radio & RG731BX DMSS Receiver **PRICE DROP** Greg Gimlick Aircraft - General - Radio Equipment (FS/W) 1 Aug 14, 2014 11:45 AM
Wanted RG731BX JR DMSS 7 Channel Sbus Rcvr Wanted! burke757 Aircraft - General - Radio Equipment (FS/W) 1 Jul 10, 2014 01:22 AM
Wanted JR 7 channel DMSS Receiver (RG731BX) and Alt or Vario Sensor burke757 Aircraft - General - Radio Equipment (FS/W) 0 Apr 21, 2014 08:47 PM
