Old Jun 05, 2015, 01:03 PM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Laser cut micro gearboxes?
I just bought a Mini Vapor brick, and I'd like to build a little gearbox to go with it. After much frustration with stock Parkzone units, it seems like a DIY option with ball bearings and a carbon fiber shaft would be a better way to go.
Can anyone suggest an appropriate motor, bearings, gearing, and mode of construction for such a thing?
Cheesehead is offline Find More Posts by Cheesehead
Old Jun 05, 2015, 01:13 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Maybe some of the info here is useful?
http://www.rcgroups.com/forums/showt...x#post29177589
epilot is offline Find More Posts by epilot
Old Jun 05, 2015, 04:59 PM
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Looks nice! I was thinking something a little bit smaller - ideally, about the size and weight of the stock Vapor gearbox. The bearings are great, though.
Maybe get a Vapor cog and a J3 motor?
EDIT: Is there a similarly sized motor from Banggood or the like? PZ motors cost too darn much, and the cogs are too fragile.
Old Jun 05, 2015, 05:43 PM
epilot is offline
epilot's Avatar
Joined Nov 2000
Never seen a Vapor in the flesh. Is it 6mm or 7mm motor?
Lots of useful motor data here: http://www.rcgroups.com/forums/showthread.php?t=2009496
Old Jun 05, 2015, 05:47 PM
funwithplanes is offline
Find More Posts by funwithplanes
perplexed genius
United States, PA, Fairfield
Joined Dec 2014
the vapor is 6 mm in diameter
funwithplanes is offline Find More Posts by funwithplanes
Old Jun 06, 2015, 05:04 AM
ghcrash is offline
Find More Posts by ghcrash
GH crash - I practice a lot
United States, OK, Bartlesville
Joined Oct 2011
You might take a look at this thread. The last picture in Post #7 is of a Vapor/Ember replacement gearbox.
http://www.rcgroups.com/forums/showt...8#post30215655
If nothing else the thread might give you some ideas for your own gearbox design.
ghcrash is offline Find More Posts by ghcrash
Old Jun 06, 2015, 11:42 PM
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Acetal is a very clever choice. I'll see if I can find some
I'm wondering if some of the can motors from tiny quadcopters might perform as well or better than their PZ counterparts.
6mm, though I'm not averse to a short 8 if it's the best option...
Old Jun 10, 2015, 09:47 PM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
I've purchased little IR controlled helicopters in department stores for as little as $12, on sale.
The latest one has the two drive motors, which will power a Playmate type plane, and it also has a small tail rotor oriented to lift or lower the tail. I'll use that with the IR control for a throttle-only indoor plane. So for 12 bux I got a 1S cell, two drive motors, the IR "radio" and the tiny tail motor with prop. That's pretty cheap.
dayhead is offline Find More Posts by dayhead
Discussion (Available) 1/35 Micro Horten VII (ho 254) - 18 inch WS Laser cut kit jingjingjing Nurflügel 53 May 13, 2015 10:54 AM
Sold Stevens Aero Sky Boy 600 nib laser cut kit MikeinNC Aircraft - Electric - Airplanes (FS/W) 1 May 02, 2015 04:41 PM
Discussion Micro Kaos Laser Cut kit bpink43 Scratchbuilt Indoor and Micro Models 49 Nov 13, 2014 03:57 PM
Discussion Laser cut micro car epilot Micro Cars 20 Sep 08, 2014 06:28 AM
