Old Jul 22, 2016, 05:26 PM
atjurhs is offline
Find More Posts by atjurhs
agony sweetns the victory
atjurhs's Avatar
Any Flying Field Across America
Joined Jul 2005
which side of the original firewall
Hi guys,
I bought a Radian XL as my first ALES ship. I'm upgrading the powersystem with a really nice geared motor designed just for ALES type flying.
I've pulled out the existing powersystem. The OEM motor was attached to a plastic bulkhead that's integrated into the rest of the plane's frame. It was attached with 4 bolt pattern. The new motor has a 3 bolt pattern. I plan to make a new bulkhead out of G-10 and marry it up to the original bulkhead.
Question: which side of the original plastic firewall do I mount the new G-10 firewall to ? Do I mount it in front of the existing firewall or do I mount it behind the original firewall ?
Thanks!
Todd
atjurhs is offline Find More Posts by atjurhs
Old Jul 25, 2016, 05:05 PM
banjo328 is offline
Find More Posts by banjo328
banjo328's Avatar
Albuquerque, NM
Joined Jan 2010
Mounting it behind the original firewall would probably be best from a strength standpoint. You'd just need long enough bolts to reach through the original firewall.....
A three bolt pattern is unusual. What motor/gear box...?
banjo328 is offline Find More Posts by banjo328
Old Jul 25, 2016, 10:38 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
From a strength point of view, the ~2kg thrust developed should be only a fraction of your fastening strength.
But from a position point of view, setting your new firewall in front of the existing and making a hole in the existing firewall just larger than the gearbox diameter will let you get the motor shaft a few mm further forward.
If necessary you could even space the new G10 firewall a bit further forward to avoid having to extend the shaft - a bit like the motor box concept commonly used in ARF sports models
Maybe there's a market for a neat CNC standoff firewall drilled for the existing firewall and the 3 hole Maxon gearboxes.
scirocco is offline Find More Posts by scirocco
Old Jul 26, 2016, 09:27 PM
atjurhs is offline
atjurhs's Avatar
Joined Jul 2005
I made a plate out of 3mm G-10 to marry-up with the 3 bolt pattern of the NEU Motor 1105-2.5/4.4/1 motor, but there was no way that it could align with4 bolt pattern that is part of the bulkhead. so this little exercise is over and onto another endeavor.
Poll Velcro - Which side goes where? RC Roundtable Electric Plane Talk 93 May 24, 2016 09:52 PM
Discussion Which side to use an adapter Tx vs Rx nick779 FPV Talk 1 Feb 24, 2016 09:17 AM
Question Which side is the front of this patch? CyberCrash FPV Talk 7 Nov 11, 2015 11:23 AM
Discussion Which side is the front side of an OS. 61 fx conrod?? flyka737 Engines 3 Aug 09, 2015 09:03 PM
Which is better stick or side by side battery packs 5150helo Batteries and Chargers 2 Nov 19, 2002 08:33 AM
